Question about Zyxel Computers & Internet
Zyxel sleep mode - Zyxel Computers & Internet
How to set up zyxel NBG416N in universal repeater mode
Yes Zyxel nbg-416n does indeed support repeater mode but you need to make sure you have at least firmware version v1.00(USA.5)C0 and you can switch to that mode via maintenance/sys op mode.
Jun 14, 2012 | Zyxel Communications NBG416N 11N 150N Wlan...
Zyxel P660HW-D1 Router. Which settings need to be changed to turn it into a repeater and connect with my main broadband router.
Can't use a router as a repeater in a wireless sense. You could set it to AP mode and run an ethernet cable from a lan port on your other router to the WAN/uplink port on the Zyxel. If it doesn't have AP mode then you could have it in gateway mode run have a different subnet on the Zyxel with DHCP.
Oct 29, 2011 | Zyxel P660HW-D1 Router
How do I bridge mode a ZyXEL 600 series ? help please
Try setting both internal and external interfaces to DHCP rather than static, or if you have legal static IP address put it on INTERNAL interface only.and leave external as automatic.
Feb 24, 2010 | Zyxel Prestige 650HW - ADSL Router...
I put it in bridge mode and can't but it back into routing mode (tried to fix NAT problems) tried using the default 192.168.1.1 and then command prompt to find the ip that way to no avail? any ideas?
hello Cadmb3220
Of course it won't work :)
Once you set your zyxel in bridge mode all it does is translating adsl signal to comething that any other pppoe ethernet device can understand.
so in this bridged mode zyxel has no IP, is not manageable and can't be accesed over an ip ...
only way to access it again is to do a factory reset ...
btw ... i'm almost sure that whatever nat problem you had - you had because you didn0t make the same rule in your firewall on the zyxel :)
Feb 17, 2010 | Zyxel P660HW-D1 Router
Wireless Problems Zyxel P660HW-D3
When you defined the name for Wireless connection with you new router, did you give it a new name? If this is a case then you can delete the old name in your available wireless network list in your lap top so it won't go back to the default one which is the old one, then you are all set.
Sep 07, 2009 | Zyxel P660HW-D1 Router
Setting up wireless for the first time. what's
you need to use station mode and it`s not like it`s unsecure.every network in the beginning is unsecure but you have to secure it using wep or wpa.take care
Jul 06, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
Still cant solve it.
The default address to get to the web interface is 192.168.1.1
The default password is 1234 (No username required)
If that doesn't work, you can restore it to the factory default by pressing the reset button on the back and holding it in for 10 seconds. Be aware that doing this will erase all existing configuration information.
Here's a link to the quick start guide:
ftp://ftp.zyxel.com/P-320W/quick_start_guide/P-320W_1.pdf
Here's a link to the Users Guide:
ftp://ftp.zyxel.com/P-320W/user_guide/P-320W_1.pdf
Jun 27, 2009 | Zyxel Prestige 320W Wireless Firewall...
Zyxel P 660HW T1 how to apply DMZ mode for a CCTV
Network - NAT - Port Forwarding - Default Server, Put the IP of your CCTV Hardware/PC
This IP will accept connection on all ports.
I never did this yet so any success please reply.
Mar 26, 2009 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
14 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
