Question about Goodman Heating & Cooling
GSC130361GB not getting cool, fan not blowing very much
    Genius:
  • Goodman Master
  • 1,363 Answers
Sounds like coil might be froze up. check outside unit and see if the larger line is froze up.
Posted on Aug 09, 2015
Message keeps popping up saying Turn off computer, problem in cooling system
you need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Nov 25, 2013 | Toshiba Satellite 1715XCDS Cooling Fan...
Why My fan is runing to often? I have Toshiba Laptop satellite L645
You need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Oct 08, 2012 | Toshiba (K000016310) Cooling Fan
Ck engine light problem on 2001 Impala
Well the code is for the circuit - the computer commands the relay to turn the fan on and it doesn't happen.
The computer provides the ground for the relay.
If you have replaced the relay and the fan and the fuse still blows, I would look for a problem in the harness between the fuse box and the fan, including the ground circuit for the fan.
The fuse for the cooling fan is usually a 30amp marked "cooling fan" in the fuse box in the engine compartment.
Do you know what the 25amp fuse that is blowing is for ?
Jul 30, 2012 | Chevrolet Cars & Trucks
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
Mini Cooper 2002 overheated, fan fuse keeps blowing
The most common cause for the cooling fan fuse to blow is a bad cooling fan motor. The failng motor will draw an excessive amount of current which actually heats up the fuse and melts it. Now if your fuse is blowing the instant the cooling fan(s) turn on, then that could be a "dead short". either inside the cooling fan motor or in the wiring going to it. Follow and inspect the wiring leading to the cooling fan motor. Check for any broken, cracked or burnt wires. If you don't see any of that, then you'll probably need a new motor. If you think you can tackle the job, most auto parts stores sell generic replacement cooling fan motors much less than you would pay at the dealership.
WARNING! - some cooling fan motors are easy to get to, and others are very difficult. Study yours carefully and then decide if you want to tackle the job before you start tearing it apart.
Sep 30, 2011 | 2002 Mini Cooper
Everytime my charger is plugged in, my laptop decides to turn off. It gets really hot underneath. Do you think i'll need a new fan?
Check the vents. Quite often it's a build up of dust on the fan and surrounding area.
Give it a good blow out and see if that helps
Feb 22, 2011 | Computers & Internet
Cooling fan fuse
most likely the cooling fan has a short in it. disconnect the connector on the fan. If it doesn't blow now its the fan motor. If it still blows you have a short from the fuse to the motor. What this means is the hot wire is touching bare metal somewhere
Jul 17, 2009 | 2002 Pontiac Sunfire
My fan isn't working
well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Jul 14, 2009 | Heating & Cooling
Radiator cooling fan 30 amp. fuse keep blowing
The fan may run with jumper wires but if it''s blowing the 30 Amp Maxifuse it's needs a new or used fan motor.It's pulling too many amps.I have almost never seen a fan relay concern.Only other thing you may check is the wiring down near the fan shoud I have seen the 2 wires get loose from the conduit & melt onto exhaust manifold.Hope tHis Helps
Apr 26, 2009 | 2002 Saturn Sl
Heating & Cooling Logo
50 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
