Question about Panasonic Viera TH-42PZ85U 42 in. Plasma TV
"channel not available" - Panasonic Viera TH-42PZ85U 42 in. Plasma TV
Technogym manual
  • Several programs available.
    • Cartoons'
      • Bugs Bunny on channel 6
      • Road Runner is on Channel 12
    • Soap Operas
      • A day in the life of Rodney on Channel 3
      • One Life to live on Channel 9
Aug 14, 2014 | Body Solid Best Fitness Spin Bike BFSB10
Missed channels
Those particular channels are not being detected because of antenna orientation or weak signal level. We have similar problems receiving digital channels 3, 6, 23, and 52 here in the Philadelphia area.
Jun 08, 2017 | RCA Dta800b1 Digital-to-analog Converter...
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
Oct 11, 2011 | Emerson EWC1304 13 in. TV/VCR Combo
I cannot program my dvr because the timer will only show ch.3 what if i want to record ch.72 with th timer?
Go to "setup" mode on the DVR, and do a "scan for available TV channels", to add more channels,
or explicitly "add" channel #72 as an available channel.
Mar 17, 2011 | Computers & Internet
All my channels are lost how do i reprogramme them?
Out your TV into the auto scan which is available in the main menu and your available channels will automatically get memorized into the TV channel position. However if you intent to get the most wanted channels in a priority then it must be done manually by searching and memorizing.
The links are available in the main menu and you can go by the display selected.
Dec 15, 2010 | Televison & Video
How do I retune my Samsung Syncmaster 19''LCD TV as channel 5 is not available.
Manually select channel 5 (NOT by pressing "channel-up" while viewing channel 4) and press the 'ADD/DELETE CHANNEL' button.
Or, run through the complete "automatic channel seek" first-time-setup function to "re-discover" all the available channels.
Oct 26, 2009 | Samsung 192MP SyncMaster 19" LCD Monitor
Programming channels
The only thing I see in the Manual is to do an auto search which will scan all available channels and saves them to memory. the faxtory setting is auto search. the search allows you to manually search for available channels. in this mode, available channel must be stored individually. the program sets your favorite channel to appear when the tv is turned on. the range is from channel 0 - 255. i hope this helps.
Sep 15, 2009 | Trinity CT-V710 7 in. Portable TV
Orion tv 1333
Try to use the add a channel tool or, search for digital channel tool. this should pull up most of your available channels in your area. if you've done this then, you may have only one active dtv channel available at this time.
Feb 04, 2009 | Orion1934 19" TV
Not all channels available
Sounds like a bad tuner or more commonly the connector on the tuner is loose and or broken.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
ITV reception
sounds like you need to go to your menu on the tv, and go scan the available channels thats available to get the fta channels, BUt your gonna need to make sure that the fta channels are available in your part of the world??. Good luck
Jun 28, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Panasonic Viera TH-42PZ85U 42 in. Plasma TV Logo
21 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
