Question about BAFX Products Camping, Backpacking & Hiking
We pulled the pole out passed the stop and cant get it back in
My Telkom line is out of order since 4/12/2017 - Refr number 466vtk041217 - 012 6642061
dont pay and stop complaining here. we cant fix that problem for you
Mar 01, 2018 | The Computers & Internet
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
May 31, 2015 | Northwest Territory Sierra Dome Backpack...
Coleman trecking pole
That is not a car or truck.
Apr 29, 2013 | Cars & Trucks
1983 Chevy G20 hot-wire question. I had to drill out the key hole a week ago and it started with a screw driver about 50 miles back. cant figure out why it wont catch. starter turns flywheel but it wo
This sounds like you said it worked fine for about 50 miles, now you can't get it to turn over and start? Have You checked to see if fuel pump is working, or if You are getting gas to engine?
Apr 20, 2017 | Holley Plumbing
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    I have trouble with my 6002 serger coming unthreaded, especially the left needle.
    check that the aerial (pole) is up all the way, also tension setting on the thread. I would expect the needle tension to be 5. now review yr threading , check this thread from cone to needle and see if the thread is wrapped twice around a loop or catching on another guide or just missing a guide. sometimes if you put pole down to cover machine at night, then come back and pull up the pole for next use, the thread may catch on back thread support, around the cone or foam under cones. its usually something simple. also chech the take up lever, is the thread passing under this?? if not that would cause breakage just as it does with regular sewing machine. the take up lever draws thread down when needles raise to keep thread feeding to needles - maybe this isnt happening? if its definitely threaded correctly try stitching very slowly and see if take up is moving??? lastly is the thread old brittle and dry?? although most locker cones are poly thread they can get brittle if very old. good idea to store the spares in a drawer long term out if daylight if you can. and cover machine up when not in use, plastic panels are adverse to sunlight and ditto for the thread. hope some of the above solves yr problem. but if you cant resolve it then take for a service, should have one every two years to clean lube and reset looper timings to get best from the machine.
    Aug 28, 2011 | Necchi 6002 Sewing Machine
    Headlight bulp replacement, passenger side, removing bulb from back of assembly without removing entire assembly
    The bulbs most likely are a three tab twist and turn replacment.
    Depress the clip at the back of the bulb for wring harness and pull gently straight back twords pass compartment, twist bulb assy to left( about a 1/4 turn when it stops gently pull towrards pass compartment.
    Reverse the process to install new bulb.
    Oct 30, 2010 | 2000 Ford Focus
    Cant ajust tensioner pully
    You have a (spring loaded) tensioner. I usually use a rachet and whatever size socket the bolt requires and use a 2 foot hollow pole as a pull handle.. Put the socket and rachet on the bolt, slip the pole over the handle of the rachet and push the tensioner back which will give you the slack room you need to install the belt. Make sure you have the belt around all the other pulley's so it will be a easier to slip it on to your tensioner. This tensioner should adjust itself by spring action.
    Jan 24, 2010 | 1993 Ford Explorer Limited
    I need info on a Poulan Pro 445 fuel line routing
    I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
    If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
    The fuel system routing is terrible, but it is all there is.
    Fuel Routing follows:
    Tank to carburetor (hose in tank with filter on free end)
    Carburetor to primer (primer draws fuel from the tank through the carb)
    Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
    Lou
    Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
    Wiring to a 3 single pole combination switch
    run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
    Mar 03, 2009 | Pass & Seymour / Legrand 1595-2SWT...
    Camping, Backpacking & Hiking Logo
    262 people viewed this question
    Top BAFX Products Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a BAFX Products Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
