Question about GE GSL25JFPBS Side by Side Refrigerator
Can't put kickplate back on GE fridge - GE GSL25JFPBS Side by Side Refrigerator
Remove kick plate
Tip the unit back and put your hand under each side in turn underneath, the kickplate is held on via clips near each front foot (the retainer lug is part of the kickplate) this will release it. To reinstall offer the kickplate up under the door panel and give the bottom a push to relocate the clips.
Mar 19, 2013 | Bosch SMS68M02AU Dishwasher
How to level my refrigerator
THERE ARE LEVELERS BEHIND KICKPLATE ON MOST FRIDGES. SCREW IN TO GO UP OR OUT TO GO DOWN
Jan 17, 2013 | GE GSL25JFPBS Side by Side Refrigerator
How to remove freezer door with water/ice dispenser on GE profile TFH22PRSM
TAKE OFF KICKPLATE ON BOTTOM OF UNIT. UNHOOK WATER LINE FROM QUICK CONNECT UNDERNEATH. ON TOP OF FRIDGE THERE IS A COVER OVER THE DOOR BRACKET. REMOVE THAT COVER. THEN REMOVE THE 2 OR 3 SCREWS HOLDING BRACKET TO TOP OF FRIDGE. THEY USUALLY ARE 5/16TH SCREWS.MAKE SURE THE HAVE DOOR SHUT OR SOMEONE HOLDING THE DOOR WHEN DOING THIS. AFTER REVING SCREWS AND BRACKET LIFT DOOR UP OFF BOTTOM HINGE AND WATER LINE FROM DOOR WILL COME OUT WITH IT.
Jan 17, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
On a whirlpool ED5VHGXMB11 how do I manual set the defrost mode ?
http://www.applianceaid.com/adaptive_defrost.html go to this site and it will tell you how to get it into defrost,also remove the bottom kickplate you should find a tech sheet either on the kcickplate or taped to the top of the fridge but it should be somewhere behind the kickplate,it has all the instructions on all tests for your machine,make sure you put it back for future service,without that paper you are screwed
Sep 26, 2011 | Refrigerators
Freezer and fridge cooling but freezer not freezing and fridge not cold enough
Their are a couple things that could be causing that.
The conderser coils under the kickplate below the doors is clogged with dust. Remove the kickplate and check/clean using a refrigerator coil brush that could be purchased from your local hardware store (Lowe's HomeDepot Ace hardware)
The condenser fan motor behind the refrig., behind the lower service plate directly next to the compressor isn't running and needs to be replaced.
Good luck,i hope this helps you to get your refrig back to cold,
Gene
Aug 13, 2011 | Amana ARS266ZB Side by Side Refrigerator
Hi, I have a G.E. 2 door fridge with ice maker mod TFG25PRY,it requires a new compressor. Can you tell me the compressor watts (refrigeration) for this model. Regards John.
Compressors are usually rated in BTU's and are found on the the spec sheet, which is usually under the front of the machine behind the kickplate.
Feb 03, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
1998 Kenmore refrigerator does not stay cool enough. Freezer seems to be okay
Sounds like your defrost timer may have gone bad. Feel your walls and if they
are hard with no give then the fridge is froze up solid not allowing any air to
circulate. Try this: Unplug for 24-48 hours. Place towels on floor to **** up
water. Plug back in. If the fridge gets cold then the defrost timer is bad.
Unfortunately this is not a cheap fix and consideration may have to be given on
replacing your unit. Also clean your cooling coils located behind the kickplate or in the back with a soft brush and a vaccum cleaner using its crevice tool.
Good luck and thanks for your question and I hope my suggestions help. Don't forget to rate me.
burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Jan 08, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
Oct 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Hi, how do I remove the water filter from my kitchenaid fridge?
whats the model theres afew different? is it located under the kickplate or is it hanging from ceiling of refrig compartment??
if its behind the kickplate should be a quarter turn counter clockwise and will pull right out, new one goes in same way (clockwise). it might be difficult but it will turn removing the kickplate might make iteasier.
if its inside the refrig compartmant push the tab to release the housing and then a quarter turn on that one.
Mar 11, 2008 | Refrigerators
GE GSL25JFPBS Side by Side Refrigerator Logo
69 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
