Question about Belmont 020 X-Calibur Dental Chair
Water syringe The water syringe on the assistant side does not spray water. Air is fine.
Line is fine, but still leaking
Take a spray bottle and put some soapy water in it; spray it on the path that air flows (line from pump to tank, pressure regulator, air line fitting) to find where the leak is. Once you find the leak will determine what has to be done to fix it.
**the soapy water spray will bubble wherever air is leaking**
Nov 01, 2015 | Craftsman 33 gal Air Compressor 6 hp...
Ac unit in the house keeps freezing up, not a window unit, central unit. The entire part inside keep freezing up, making knocking noise, and not blowing cool air. The out side part is fine, no problems...
There is a coil out side in the unit , it needs cleaning, there is an acid that is used to clean it. Its an easy job, pull the top open and use a stick or something to keep it up so you can spray the coil, with the unit off let soak 10 mins then spray wash with water hose. done
Sep 29, 2013 | Heating & Cooling
Does anyone know the quantities for making your own nasal saline spray? The ones in the shop are so expensive?
Try this recipe for a saline irrigation spray;
- Mix 1/4 teaspoon of salt and 1/4 teaspoon of baking powder into 8oz of warm water.
- Use a bulb syringe to squirt water into the nose.
- Lean over the sink and hold one side of your nose closed. Squirt water into it and let it drain out, then blow your nose.
Feb 18, 2013 | Health & Beauty
New out of the box. won't dispence water to make espresso
Hi. Is your pump working. Should be able to hear it. If its making a really loud noise then it could be an air lock in the line. Try using the hot water button to bleed the system. Also see if it will despence water wiyhout any coffee in handle. Dazza REPAIRER
Sep 23, 2011 | DeLonghi EC155 Espresso Machine
My test indicated that I needed to clean the print heads. After 6 cleanings, all is ok, except the Magenta pattern is about 1/3 complete with gaps. The ink is about 1/2 full, and all other colors are...
Hi Mr. walter
This is a problem of clogging of head. You need to un-clog the head hence you need to have with you the following
1. A syringe any capacity
2. Hot water
DO NOT USE ANY OTHER GLASS CLEANING LIQUIDS
1. First take the carriage cradle out of the capping station.
2. Take the hot water in the Syringe and slowly pump a little qty. of water in the Magenta inlet nozzle
3. Then pull the syringe back so it will get the water from inside out in the syringe.
4. Inspect if any small derbies of clogged ink is being sucked by the syringe.
5. Now again pump a little hot water into the ink inlet nozzle
6. Repeat Step 2 again for 3 more times
DO NOT PUMP THE HOT WATER WITH A GREAT FORCE THIS WILL DAMAGE THE HEAD.
Jul 16, 2011 | Epson Stylus 2200 InkJet Photo Printer
Water leak in front of frig.
use a syringe with clorine bleach to blow out the drain hole,(a meat/gravy syringe works fine...)
Jul 21, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
Panasonic a/c 'spitting' water out the sides.
your water pan is not draining and fillin up with water causing the fan to spray it around
Jul 12, 2009 | Panasonic Room Air Conditioner CWXC104HU
Spray is very fine or not spraying
Any air leaks in the suction portion of the machine will cause it not to spray or spray weak. This is a airless paint spray correct? Your paint should be at least thin down using 1 gallon of water for a 5 gallons of paint. I find Baer paint is even thicker and had to slowly add more water.
To check if it is your paint. Fill a bucket of just water and see if it will spray your water. Of course after it gets a good prime. Let it recirculate until the water is coming out of the bypass as a solid stream. If it does not spray water then you have either a air leak or your pump packing needs replacement.
Let me know the results and the make and model of the machine.
Mar 20, 2009 | Binks Air Tools & Compressors
Refilling LC37's
This answer:
http://www.refillinstructions.com/Brother/B6.htm
is wrong.  It doesn't work for LC37 cartrdges, because they are not the same as LC51.  There are no instructions on that site that work.  Here's what I do:
You don't have to take the shell off the cartridge; it would be better if you did, but it doesn't come off nearly so easily as the above link says.  It is glued together, so to take it off, you have to split the seam with a very sharp knife.  If you can do this, the refilling job will be a lot easier as you will be able to see what you are doing.  If you don't want to attempt it, you can still fill it "blind".
You need a 10ml syringe.  You don't need a needle.  The tip of the syringe is not quite long enough, so I had to make an extension for it.  I used a piece of skinny tubing from the inside of an old spray bottle.  I cut about 1" (2.5 cm) off and attached it to the end of the syringe using epoxy putty, like the stuff for patching leaking radiators.  You can get it at any hardware.  I put a piece of wire through it to keep it aligned while I was molding the putty around it.
After it sets, fill the syringe with 5ml of ink.  Push it into the outlet hole of the cartridge while twisting it until it is firmly stuck into the hole.  Turn the cartridge/syringe assembly so the syringe is up.  Pull back on the handle and **** 5ml of air from the cartridge.  Then gently squeeze the 5ml of ink in.  Fill the syringe with another 5ml of ink and repeat.  You may find it hard to **** air out without getting ink as well.  The cartridge is built like a labyrinth inside, so there are lots of places for ink to get trapped.  Twist and turn the cartridge and push and pull until you've got the 5ml of air.  Then again put the syringe topmost and gently squeeze in the ink.  If you have removed the shell, this will be easy to do.  The main point is to make sure you remove the same amount of air as the ink you put in.  Do not push the plunger valve.  If you do, you very likely will get a handful of ink.
An LC37 only holds 10ml of ink, not 30 like the LC51.
When you are finished, you can gently push the plunger just slightly; if any ink comes out, you need to remove some more air.  You can damage the printer if you install a cartridge that has pressure inside it.  New cartridges have a vacuum inside; you can hear them go "whoosh" when you click them into place.  If not a vacuum, you need to at least have neutral pressure before you install it.  This is very important.  The printer has sensitive electronic sensors mounted roght at the business end of the cartridges.  If any ink gets spilled in there, your printer will likely be ruined.  Be warned.
It is about impossible to do this without any spillage.
Wash the cartridge in running water, shake out the excess thoroughly and then dry it with a paper towel.  Don't install it unless it is totally dry and not pressurized.
Mar 22, 2008 | Computers & Internet
Belmont 020 X-Calibur Dental Chair Logo
87 people viewed this question
Top Belmont Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Belmont Medical Expert? Answer questions, earn points and help others
