Question about Firethorn Holdings PSECU
Psecu for droid
When taking the photo of the check the image goes sideways and won't work for the deposit
Tip
How to convert DVD/Video to Motorola Droid?
Motorola Droid finally rooted! The Motorola Droid is the first Android 2.0 with a superb high-resolution screen, a slim shape, a physical qwerty keyboard and Google's latest build of Android (the operating system). The web is richer. Photos are sharper. Videos pop. It has the most advanced browser with a blazing-fast processor and 3G speed for faster search. It has the world's thinnest QWERTY slider at 13.7mm. It can help you navigate turn-by-turn. It has a 5MP camera with a flash, plus loads of great camera features and a DVD-quality recorder to capture all the richer, bigger, wider experiences you're going to have.
Multimedia capabilities
Motorola Droid is coming with the built-in media player that supports AAC, H.263, H.264, MP3, MPEG-4, WAV, WMA, eAAC+, OGG, AMR WB, AMR NB, AAC+, MIDI. Unfortunately, there is no syncing software to help you manage and transfer your music. As it is right now, you have to use the old drag-and-drop method using the USB cable or sideload them using a microSD card.
Of course, you can also download songs via the Amazon MP3 store. The store allows you to browse by album, song, artist, or genre. You can download the DRM-free songs over Wi-Fi as well as Verizon's 3G network, though the Droid advises you switch to Wi-Fi when possible since it's faster.
The bad is, Motorola Droid is not capable to run and read your DVD disc. And, for videos, even it supports MP4, AVI is still the main stream of video container right now. Then, what can you do if you already have a collection of digital video content in AVI, MKV MOV, MOD, M2TS, etc, or on DVD disc, and you are eager to watch them on your lovely Motorola Droid?
Below, I will demonstrate how to rip DVD to Motorola Droid, convert videos to Motorola Droid.
Software you will need
Since Motorola Droid is not compatible to read AVI, WMV, MPEG-2, etc, here we will need a 3rd software to assist us to convert video format. Among those video converters, I would like to take Aimersoft Video Converter Pro for its forward-straight GUI and full functionalities. With Aimersoft Video Converter Pro we can easily finish the DVD conversion and video conversion for Motorola Droid.
http://www.aimersoft.com/images/tutorial/video-converter-pro-function-sc.jpg
Get Start
1. "Add Video" or "Load DVD"
If you are to rip DVD, then you are freely either choose load DVD Folder, ISO files or IFO files.
2. Select output format by clicking "Profile" drop list
Be noted that Motorola Droid is able to playback videos with resolution 720 x 480 (D1), frame rate 30 fps. Below is the snapshot that shows where you can set the video parameter.
http://www.aimersoft.com/images/tutorial/convert-dvd-to-Motorola-Droid-settings.jpg
3. Set output destination through "Output".
4. Edit DVD movies/ Videos if needed.
Under the "Edit" menu, you can split & merge your files, discard the black bar, add watermark.
Be noted that, if it’s the DVD movie you are to edit, you need to choose the "DVD title" to process to the edit panel.
5. "Start" conversion.
Authorized publish
How to rip DVD to Motorola Droid, convert videos to Motorola Droid
on Mar 08, 2010 | Cell Phones
Sylvania sdpf 1089
Rotate images correctly. : NIX Digital
https://support.nixplay.com/entries/66055804-Rotate-images-correctly-
Apr 7, 2015 - images that are uploaded to the frame should always display .... I amdisplaying images from my SD card. ... of photos coming from USB or SD will stillneed to be rotated if there is an exif ... "save as " from the account they are the correct orientation on my computer. .... Everything worked correctly after that.
Photo Rotation Problem - Community@Insignia
community.insigniaproducts.com/t5/...Photo.../Photo-Rotation.../td.../508...
Dec 28, 2009 - I have a few pictures that I already rotated correctly on my computer. Even so, they display incorrectly on the digital frame (buildings and people. ... When I bring the picture back to the picture frame, the rotation is still .... Just extra info - If I put the picture directly into Internal Memory .... Save as 24-bit Bitmap.
Galaxy S3: Photos are always being rotated! Why! - Android Forums ...
forums.androidcentral.com > ... > Samsung Galaxy S3
Dec 31, 2013 | Office Equipment & Supplies
Why are Remote Deposit and Check 21 Act so useful?
The check 21 Act (21st century act), which allows Remote Deposit, was an important step forward in banking.
Part of its creation was to ensure that financial transfers could take place also in case of catastrophes, like 9/11, when rapid long-distance transportation is impossible.
Before Remote Deposit was available, whenever a check from one bank was deposited into another bank, the funds weren't accessible to the customer until the banks physically exchanged the paper check. After Check 21 took effect, instead, customers could easily send an image of the check to the bank and immediately access their funds.
Aug 26, 2013 | Finance
My SD800IS was working fine while in the very hot/humid environment of Yap. I took it out of my air conditioned room and went to take a picture almost immediately. The view finder, the LCD image and the...
The foggy images and lens was due to condensation caused by the camera's surfaces being cold in a humid/moist environment. Usually this happens and goes away without issue. If you believe issues are continuing, consider placing the camera completely in a bowl of uncooked rice. The rice should help eliminate the moisture in the camera.
Hope this helps.
May 06, 2011 | Canon Cameras
Droid (2 GB) Cell Phone: how do i set my background to fit the hole screen?...
on every droid that i have seen,if you change the resolution of the picture to the largest,then the image will fit.If you take a picture with your droid,it should just fit the whole screen.
May 17, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My droid gors to start up screen every 3 minutes
Try to do a firmware restore to make sure your system is 100% intact.Ifit still doesn't work, there may be an issue with your logic board.Ifyou're not covered under warranty there are Droid Repair guides that show how to open a droid.Watchout for the ribbon cables,those tear easily. Replacement parts areusually available on Ebay.There are third party services that can do itfor you Droid Repair.
Jan 01, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
PICTURES
The camera has a built-in accelerometer, so that it automatically orients the image as soon as you take it. If you are holding the camera sideways, you'll have to turn it back to normal in order to see the image right side up.
Sep 22, 2008 | HP Photosmart R927 Digital Camera
Delete & double pictures
you probably have the burst on. I have done this lots of times. before you get ready to take your shot, push the delete button until the multi-burst icon goes away. this will be represented by what looks like stacked boxes followed by either an H, an L, or a sideways 8 (or infinity symbol). that should solve your taking 2 pictures at once thing.
Aug 17, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Firethorn Holdings PSECU Logo
70 people viewed this question
Top Firethorn Holdings Apps Experts
Erin Wood
Erin Wood
Are you a Firethorn Holdings App Expert? Answer questions, earn points and help others
