Question about Vehicle Parts & Accessories
How to change fuel filter on 2010 Hyundai Santa fe 2.2 diesel
e-Guru
  • 3917 Answers
SOURCE: How to change fuel filter in 2004 Hyundai Santa Fe
Please follow the steps to change the fuel filter. You would need to remove the left rear seat (four 14mm bolts). I think you'll need to finish cutting through the tabs on the carpet to be able to lift up the carpet. Then remove the access cover. You can then remove the fuel pump from the top of the tank.
Thank you for contacting Fixya.com
Posted on Jul 26, 2009
  • 84 Answers
SOURCE: Change serpentine belt 2004 Hyundai Santa Fe
it uses a spring loaded tensioner.use a breaker bar to rotate the tension and it should just come off.if u need a pic or anything else to do it let me know,
Posted on Oct 05, 2009
techbuster
  • 5081 Answers
SOURCE: i cant find the fuel filter from my 2002 hyundai
The fuel filter is located in the fuel pump which is in the fuel tank.
Posted on Dec 26, 2009
  • 94 Answers
SOURCE: where is the fuel filter located on a 2002 hyundai
The fuel filter is located inside the fuel tank. It is part of the fuel pump assembly.
Posted on Aug 12, 2010
Testimonial: "ty"
  • 120 Answers
SOURCE: how do you change a fuel pump on a 2002 hyundai
You will need to remove your seat in the back of the car. The pump is under the drivers side rear back seat. You will have to remove the floor cover. You should see a panel. remove panel on floor and you will see the top of the fuel pump. There may be a lock ring holding it in which you would move counter clockwise and then the pump should come oute63c077.jpg
Posted on Oct 17, 2010
I CHANGED FILTERS AND PUMP BUT STILL GETTING CODE P1186
fuel pressure too low,did you reset the light?? if not,you need to,if so,you have a blockage,check the fuel rail, and lines,also,is the fuel filter on the right way?
Apr 27, 2015 | Santa Fe 2010 Hyundai Owners Manual,...
Error code p1186 2007 hyundai santa fe diesel need more information on low fuel pressure
there have three factors may be cause the problem,
1.The filter is a source for low fuel pressure, because it is stoped up or is cloged.
2. The fuel pressure regulator is another.
3. The pump itself.
Tech 2 software
Jul 18, 2012 | 2009 BMW 3 Series
How do I change the fuel filter on a 2006/7 Hyundai Santa Fe 2.2 CRDT CDX safely?
There is no external type fuel filter on the Santa Fe. It is built into the fuel pump module in the tank,you rould have to remove your rear seat bottom cushions and get to the access plate and remove the pump module. Can be very time consuming if you have never done this before.
Oct 20, 2011 | 2007 Hyundai Santa Fe Limited
2007 hyundai santa fe fuel 2.7 6 cyl fuel filter location?
how to change the fuel filter on 2007 hyundai santa fe
Sep 20, 2010 | 2007 Hyundai Santa Fe Limited
How do I change the diesel tank pump on my 2003 hyundai santa fe
remove rear seat components, you can access to remove now the fuel pump,
Jun 25, 2010 | 2002 Hyundai Santa Fe
2003 Santa fe fuel filter.....
dear friend:if you got the filter unit in your hand then clamp the metal part in a vice and unscrew the filter part,sometimes it appears that it cannot seperate but it can.force and a filter remover will do the trick
Sep 22, 2009 | 2004 Hyundai Santa Fe
Have just changed fuel filter on santa fe 2001 turbo diesel now having problems starting it
Maybe a dud filter or an air leak Check rubber seal off old filter did not stay stuck to housing
Jul 09, 2009 | 2001 Hyundai Santa Fe
Vehicle Parts & Accessories Logo
16 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
