Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Fan is not blowing air at its full speed - Mastercool 67471 Evaporative Cooler Air Conditioner
  • 614 Answers
Check filer. Possible stopped up evap coil. You possibly clean this yourself. Use a stool bruch to clean coils. Does not bend fins. If this does not work call service tech to chemically clean coil.
Posted on Jun 14, 2009
I have fujistu H series, the laptop is displying a fan error when switching on and fan stays at max speed.. any help?
could be your fan is full of dust and the heat sink of the cpu making it overheat. there is a vent where it would blow the hot air out. if your not getting air flow the vent might be clogged
Jul 26, 2015 | Cars & Trucks
03 Merc. Sable. AC works fine until I slow down in traffic, then it will slowly switch to blowing warm air
Have your a/c condensor fan checked out. It most likely is not working, or is not functioning at full speed. When you are driving air is being pushed through the condensor helping to keep your a/c cold, but when sitting in traffic there is no air flow if the condensor fan is not functioning at full speed.
Jul 26, 2014 | 2003 Mercury Sable
We have just bought a 1996 Sun Voyager. It was a one owner and well taken care of. The ac comes on and blows cool air but has no force of air behind it. Does anyone know what it could be?
what about the heater. the a/c and heater share the same fan motor. If there is no force in the heater as well it may the the fan is not turning at full speed. should be able to hear the fan as well as feel the air from the ducts. another possibility is a blocked duct way. If you can hear the fan blowing full speed check the duct for obstructions.
Sep 08, 2013 | Dometic Rooftop RV Air Conditioner
Audi a4 2.8l no heat
take the top off the filler cap run engine to boil. keep it full off water to the top. you will see air bubbles coming out as the engine gets hotter. squeeze the pipes on the rads to help the air come out. when fan kicks in turn engine off and leave to cool down.while you are doing this make sure the fan for heater is off but is on full heat. can have fan on number one on speed that is fine.
Mar 01, 2013 | 2000 Audi A4
My cooloing fans are running full speed all the time which is very loud and annoying. how can i fix this?
Firs thing you need to do is to find our why they are running full speed. My guess is that your computer is dirty inside and it is overheating, thus causing the fans to run full speed trying to cool it off. Disconnect everything from the pc and take it somewhere to clean it out. Remove the side panel an use a can of compressed air or an air compressor to blow all dust out the interior of the pc. Pay close attention to the heat sink on the processor and the cooling fans. When blowing around the fans hold the fan in place with a pencil to prevent it from spinning as this might damage the fan. You need to clean out the inside of a pc sitting on the floor every 6 months. If you have cats or dogs that shed living inside then every 4 months. If it is sitting up high and you have no animals then every year may be good enough.
Oct 05, 2010 | HP Pavilion a1010n (PS563AA) PC Desktop
No heat
your blower motor resistor needs to be replaced if you only have one speed its a small inexpensive part runs about 15 dollars easy to replace.
Jan 17, 2010 | 2000 Oldsmobile Silhouette
Strange Problem Bravo Ute Air Conditioning
the blower motor has no affect on the AC system,
start the engine and turn on AC and watch the AC compressor to see if clutch engages,if it doesn't the system isn't full,if you are correct the clutch should be engaged and should quit when you change heater speeds,
Dec 23, 2009 | 1988 Mazda B2600 Cab Plus
HEATER NOT WORKING IN 2001 LEXUS RX 300
you most likely have a bad airmix servo. this happens alot on these. they are expensive to replace too.
Sep 10, 2009 | 2001 Lexus RX 300
Heater on driver-side blows barely warm air other vents blow cold
the most probabale cause of this would be a disfunctional hear core if you replace your heater your heater will more than likley work the the way it's supposed to
Jan 18, 2009 | 2001 Dodge Grand Caravan
Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
Dec 03, 2008 | 2000 Ford Escort
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
206 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
acrman404a
Level 1 Expert
Steve F
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
