Question about Kenwood DNX570HD
NO SOUND DNX570HD
NO SOUND FROM HD RADIO
Boston Acoustics Recepter Radio HD stopped working - no power. The power supply is fine. is there a fuse in the radio?
There should be a fuse in the back but it would only blow if the wiring is funny because the car's fuses are closer to the power supply and should go first, but try anyway
Apr 24, 2014 | Boston Acoustics Recepter Radio(r) HD
IPOD cable doesnt work on my DNX570HD
I have the same problem, did you find a solution?
Jan 10, 2014 | Kenwood DNX570HD
Check error code 3-1
i got error code 3-1 while installing firmware update how do i get code information? gps doesn't work now either, white screen
Dec 17, 2013 | Kenwood DNX570HD
Sound bad on hd channels
I ended up installing a stereo graphic equalizer/ sound limiter from Radio Shack. I use the ear phone output go into the equalizer / sound limiter then go into a speaker system. You can adjust the EQ and limit the volume. I also had problems with load portions of movies, commercials and low/ high audio. This also allows sound enhancement with some buttons on the EQ. It is usually used in sound reinforcement as in Band and public address systems also higher end stereos systems. you will need a set of powered speakers for this solution so the EQ has somewhere to go to.
Mar 25, 2010 | Vizio GV42L 42 in. LCD Television
Harman kardon radio does not have fader. HD Amp is
unit needs to be programed for the fader to go active at a dealer or by Iron Cross Audio
Feb 06, 2010 | Harley Davidson 426290 AM/FM Radio
The radio works and then there is no sound but there is power if i turn it off and back on there will be sound and after afew mins it repeats its self i have a 2007 street glide
Sounds like the vox function of the intercom or HD CB is trying to cut in. Have you got the owners manual out and made sure these function have been turned off? There is quite a lengthy trouble shooting checklist in reference to the HD Radio system and it starts out having you make sure the other functions have not been turned on.
Aug 14, 2009 | 2008 Harley Davidson FLHX Street Glide
I have a Sony Walkman TV/Weather/FM/AM SRF-M37V. I need to know
The radio won't get TV sound anymore after the switch. And no, nobody is selling a digital receiver for the TV sound yet. All this radio is good for now is regular broadcasting and the weather band.
Jun 01, 2009 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
2006 ultra radio has no sound
This is a very common problem with this radio there is a part in the radio that controles volume and it breaks down after a period of time due to vibration... If you need any repair help you can email me at HRmotors@aol.com I no these radios inside and out and would be happy to help you- thanks
Jan 13, 2009 | Harley Davidson 426290 AM/FM Radio
Kenwood DNX570HD Logo
77 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
