MONITOR DISPLAY PROBLEMS
MY MONITOR IS DISPLAYING TWO BRIGHTNESS LEVELS. THE TOP HALF IS BRIGHTER THAN THE BOTTOM HALF.THE TOP HALF IS THE PROBLEM.THEN SUDDENLY WHEN I WAS USING THE PC THE LAST 2 DAYS, THE MONITOR RESTORED BACK TO ITS NOMAL BRIGHTNESS LEVEL.THEN WHEN I TURNED OFF THE COMPUTER AND TURN IT ON AGAIN THE PROBLEM RETURNED.I CHECKED FOR ALL THE WIRES . THEY WERE ALL CONNECTED PROPERLY.MY PC IS AN INTEL AND ITS ABOUT 2 YEARS OLD.ANY HELP IS REALLY (SERIOUSLY) APPRECIATED.
  • 378 Answers
The display has a loose connection in every side. try pressing the both side by hand.
Posted on Jun 14, 2009
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Hi there, We have a LG Flatron W2253TQ monitor and the display is half normal, half very bright. There's a perfect line down the middle - the left half displays normal colours while the right half...
It could be some sort of "Demo" mode on the display, try going into the menu of the display and looking for settings relating to Flatron F-Engine, it has a demo mode that could be the problem. That is the most likely cause since its exactly half the screen.
May 17, 2011 | LG W2253TQ-PF Monitor
AC power the monitor doesn't get brighter. I can't also change the monitor's brightness and i cant change my volume
check your power settings for brightness or right click on desktop and click on display go to brightness, volume click on the speaker on the bottom next to time,
Apr 13, 2010 | Samsung P30 Notebook
My computer screen display button isn't working. want to make my screen brighter. is there another to make it brighter?
hi, there is an alternative solution to solve your brightness problem get into your display adapter properties and level up the brightness but it all depends on your graphics adapter could you tell me more about it ??
Mar 20, 2010 | Computers & Internet
Screen not bright as normal , how do you make screen brighter?
<Fn> and up-arrow key Increases brightness on the integrated display only (not on an
external monitor).
<Fn> and down-arrow key Decreases brightness on the integrated display only (not on an
external monitor).
Jan 07, 2010 | Dell Inspiron 6000 Notebook
Bottom half of monitor displays top half of desktop
You could try a different resolution for the monitor.It's possible the monitor cant support the resolution your trying to display your desktop at.
Jun 01, 2009 | ViewSonic GS773 (White) 17" CRT Monitor
Acer AL11511
To even things out you need to use the controls on the monitor to lower the brightrnes. to acceptable levels. When playing a DVD there are seperate controls in the software and your graphics driver to adjust the Video Overly settings. Look for settings called gamma and brightness in the video overlay settings in the windows display properties panel. This should help even things out some. Deal is to crank down the brightness on the monitor and crank it up in the video settings in windows. It will make the DVD's brighter and rest of the time the regular screen darker.
Jun 26, 2007 | Acer AL1511 15" LCD Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
Computers & Internet Logo
126 people viewed this question
Alun Cox
David Payne
David Payne
