Question about Dewalt DW505 Electric hammer drills
Diagrama de coneccion switch de taladro dw505 dewalt
Tengo problemas con la coneccion de los cables de prender y resetaer
Aqu? hay un diagrama de la conexi?n:
Espero que esto ayude! No te olvides de evaluar!
Dec 21, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
I need the electric schematics, trying to replace the switch.purchased switch thru the dewalt website.
Schematic from a dealer for converting an old type 1 switch on DW-505 hammer drill a to the new switch. 124845e.jpg
Oct 04, 2010 | Dewalt DW505 Electric hammer drills
Drill Is Dead Fuse O.K.
Check the brushes for wear.
Most likely the cord has a broken wire , usually happens close to the handle of the drill.
To test, split the case ( puzzle screwdriver bits are avaliable from hobby shops ) and run a test light on the cord from the plug to the switch.
If the cord is ok , test the switch , they are quite flimsy on De Walt tools so be careful.
If the cord is faulty cut the damaged section out and shorten it.
If the switch, replace it . Check price, they are very hard to get here in New Zealand and very expensive.
If the Brushes, these should be avaliable from your De Walt retailer.
While you have your drill apart, check the bearings, De Walt uses common sizes,easily avaliable from a bearing shop and prone to seizing up and burning out the armature.
Mar 17, 2010 | Dewalt DW505 Electric hammer drills
Bearing Removal
hi
use a puller bearing.
regards savumihai71
Jun 20, 2009 | Dewalt DW505 Electric hammer drills
Need wiring diagram for dw505-2 trigger
Here is your parts diagram just in case you need it.
http://www.ereplacementparts.com/dewalt-dw505-type-hammer-drill-parts-c-1009_9661_2281.html
And here is the number to a factor tech which could answer your question on trigger wiring. There is no diagram available but, I'm sure a tech will get you up and going.
(702)889-6025 ask to speak to a tech.
Mar 31, 2009 | Black & Decker Dewalt No.DW505 Heavy Duty...
Engine compartment relay & fusebox
Un sitio que tiene mucho informacion sobre diagramas es bulldogsecurity.com Dios te bendiga
Feb 02, 2009 | 2000 Hyundai Elantra
Dewalt DW505 Electric hammer drills Logo
143 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
