Question about Health & Beauty
What kind of batterie for scale model tx655 - Health & Beauty
What kind of battery do I need for Homedics Lithium Electronic Scale
Here are the Instructions for SC300:
http://web.archive.org/web/20061029012330/www.homedics.com/prod/getpdf.aspx?name=SC300.pdf
Page 2 says the scales require a 3 volt CR2032 lithium battery. These can probably be found wherever batteries are sold - WalMart, Target, etc.
Dec 09, 2014 | Homedics Health & Beauty
HOW DO I CHANGE BATTERIES IN OZERI BATHROOM SCALE MODEL ZB13
On the back of the scales under the Ozeri sticker, you will find the battery cover. Remove the cover and replace the two CR2032 batteries (model ZB13).
Sep 04, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
What size lithium battery?
There's no way of telling since you don't list make and model number. Your scale could be using a standard, readily available battery, or it could have a custom cell. If it's a custom cell you'll have to buy it from the scale maker. If it's standard you can buy it locally or order online. To find out which, do one of two things: open the scale and get the number off the dead battery, or do an internet search using your make and model of scale plus the word "battery" as the search terms.
Sep 03, 2014 | Health & Beauty
I have the thin kitchen scale. After changing the battery, the display keeps flashing. How do I get the scale to work again?
I had the same problem, I am not sure why but it seems like the circuits misfire when you change the batteries (perhaps a capacitor holding a charge or a diode stuck).
I got mine working again when I put the batteries in backwards (trying to discharge any capacitor that might be holding a small charge still) and then hit the power button with the batteries in backwards; then put the batteries in properly and hit power again.
please note that I am NOT an electronics professional and I have no idea if this is harmful to the scale or not, but it worked for me and the Polder scale is working as designed once I did the procedure. Hope it helps.
Jun 24, 2014 | Polder Slimmer Digital Scale
Model ww66
In the event that the scale battery needs to be replaced, (display shows "Lo"),
open the battery cover on the bottom of the scale and replace the old battery with
a new 3V lithium battery.
Jun 04, 2014 | Conair WW60 Weightwatchers Scale
How do you install the 9volt battery and where?
It depends on the scale, usually there will be a little door on the floor side of the scale that you can open or unscrew. Some scales even take 2 AA or 3 AAA batteries. What kind of scale is it?
Feb 11, 2013 | Health & Beauty
I need a manual for simply bathroom body analysing scale
Could someone tell me the battery needed for the Simply Bathroom body analysing scale - model 4528?
Thanks
Apr 16, 2012 | Health & Beauty
We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Feb 23, 2009 | Taylor & Digital Scale Lithium Scale
Health & Beauty Logo
50 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
