Question about Apollo Ai-1000 Overhead Projector oh-apollo
User manual apollo ai-1000 overhead projector
I have an Apollo Ventura 4000 overhead projector. The Image is distorted and I can't seem to get is straightened out. How to i fix this problem?
Yours has a three element vari-focal lens system... is the bottom lens missing maybe?
I mean it's a really BASIC projector... is the "reflecting mirror" loose or out of place?
Apollo Ventura 4000 Reflective Portable Overhead Projector VWR
Anthony
Apr 12, 2018 | The Office Equipment & Supplies
How do I turn off the machine safely?
Do people still use those?
OK. Dim the lamp, leave the fan on for about 10 minutes.
Turn off unit and LEAVE UNTIL COOL.
Feb 13, 2015 | Apollo Ai-1000 Overhead Projector...
How do i change the lens from a circle to a square
there's a fresnel lens inside the projector that might be upside down. try flipping it over.
Mar 11, 2014 | Apollo Horizon 2 OpenHead Overhead...
Replacement bulb for Apollo Horizon 2 Projector
ebay or divine lighting dot com has the cheapest bulbs and best selection
Jan 13, 2014 | Apollo Office Equipment & Supplies
When I turn on the overhead projector it displays picture on the ceiling. Need to adjust to show on the wall. Do not have a manual.
Hi! This is a pretty common problem with overhead projectors. At the top of the arm that's over the unit, there should be a lens unit. The unit needs to be rotated so that one lens points down, and one lens points towards the screen. Once the lens is rotated properly, the lens unit is moved up or down in order to focus. There's usually a knob to turn to move the lens up or down.
Oct 28, 2013 | Apollo Horizon 2 OpenHead Overhead...
Apollo AI-1000 overhead projector--changing the lamp
i believe it's with the clip on the right side, but also look at the rear and bottom.
Dec 04, 2009 | Office Equipment & Supplies
Apollo Horizon2 overhead projector shut off after 5 minutes of operation
overheating. clean out the projector with canned air and check the fans for operation. reset the settings for factory default. if you replaced the lamp recently, reset the lamp timer through the menu.
Nov 05, 2009 | Office Equipment & Supplies
Apollo Ai-1000 Overhead Projector oh-apollo Logo
320 people viewed this question
Top Apollo Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Apollo Office Equipment and Supply Expert? Answer questions, earn points and help others
