Question about Williams Lectric Shave Electric Razor Pre-Shave with Soothing Green Tea Complex -- 7 oz
Little bumps have appeared on face after using lectra shave
How do you shave a beard,ive tried and it doesnt shave
  1. Choose an appropriate razor. ...
  2. Keep your shave kit ready and clean and sharp. ...
  3. Trim your beard down first. ...
  4. Wash your face with an exfoliant facial wash. ...
  5. Apply shaving oil. ...
  6. Heat your pores. ...
  7. Use a brush to apply shaving cream, if possible.
How to Shave Your Face
Visit this site fore more details.
Sep 11, 2016 | Health & Beauty
How to adjust
Those are funny little planes - they're wicked handy when you need one. I like mine a LOT.
They ARE coarsely built, not a "fine" tool, but they do a fine job.
Loosen the little screw SLIGHTLY, then either bump the rear of the iron (to extend it more) or the rear of the plane (to extend the iron less) against a piece of softwood (bench, sawhorse, 2x4, hammer handle). When it's where you want it, tighten the little screw again.
Adjust the plane's mouth (assuming that you're using it as a bullnose plane, not as a chisel plane) by loosening the big screw, then just sliding the bullnose front & rear.
Remember - planes are meant to SHAVE wood. The iron should NOT take off a thick shaving, it should take off a shaving no thicker than one sheet of toilet paper. The iron should BARELY peek out from under the plane.
Jan 14, 2014 | Stanley 12 - 975 Contractor Grade Bull...
This is the first time I am shaving with an electric shaver, is there anything I need to know?
If your switching to electric shaver or it is the first time you shave you will need to give your face three weeks to adjust to electric shavers. Try not to fluctuate back and forth between blade shaving and electric shaving during the first three weeks.
Feb 06, 2013 | Health & Beauty
Shaving with an electrical shaver is considered to bet wet or dry shaving?
Most electric shavers are dry, meaning that you don't need any gel or a shaving cream in order to shave although there are some unique wet electric shavers' models on the market.
Why should I shave with the growth direction?
The reason why you should shave with the hair growth is because there is less of a chance of nicks and cuts, and because it reduces the chance of ingrown hairs and razor bumps. Shaving with the hair growth tends to be a little easier on your skin as well.
How should I use shaving oil?
First you should thoroughly wet your face with warm water. Than you should put 5 drops of shaving oil in your hand and massage into your face. Using shaving oil is advised if you want to create a goatee otherwise it can be bad as you don't want to irritate the same spot by shaving it over again because you cannot easily see where you applied the shaving oil.
Should I clean my face before I shave?
Many skin care experts recommend cleaning your face with a facial soap before shaving in order to help remove dead skin and dirt. You can also use warm water as a per-shaving cleansing.
How can I avoid ingrown hairs and bumps?
In order to avoid ingrown hairs and bumps on your skin you should use the combination of proper wet shaving technique and the use of special sensitive skin products.
Jan 10, 2013 | Health & Beauty
Can i use shaving cream with a norelco electric shaver?
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
Apr 26, 2009 | Philips Norelco Micro 5625 XL Electric...
Williams Lectric Shave Electric Razor Pre-Shave with Soothing Green Tea Complex -- 7 oz Logo
Top Williams Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Williams Health and Beauty Expert? Answer questions, earn points and help others
