Question about LG Electronics - 42LD340H - 42 Inch Tv Widescreen
No HD Signal
All analog channels come in but no HD channels..?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Check with your cable company
Posted on Jun 03, 2015
How to tune samsung tv
Mono is the first point I am stuck on. Mono is an audio reference but I am going to assume that you are only receiving the analog channels and not the digital. If you are coming off of an antenna then the antenna has to be HD to receive HD channels over the air. If you are off of a cable box then this has to be dealt with from your provider. You will also need an HD ready TV or if you do not you will need an HD converter box to make your tv work with the digital signal.
Apr 02, 2014 | Televison & Video
Why my jvc television hd61z456 not showing in high definition
What is the signal source that you are watching on your HD61Z456?
The problem you describe usually happens when you aren't using an HD source or have downgraded the signal by the composite input on your TV. (Composite cables only support 480i SD signals.)
You will only see 720p HD content from HD sources, if you use HD compatible inputs. Some OTA channels are also broadcast as only analog signals (usually the -2 and higher sub-channels). If you have cable or satellite, make sure that you have the HD programming and have tuned to the HD version of the channel.
The HDMI and component inputs both support HD signals.
I hope this helps. If you are watching an HD source and the problem persists, I recommend trying new video cables. Next, check if you are getting interference from your devices by using a cable with a Ferrite core. See http://www.monoprice.com/Category?c_id=102&cp_id=10240 for HDMI cables with Ferrite cores. The cores help block interference. If you have very long cable runs, check the behavior with shorter cables between the source and the TV.
(I am assuming you aren't using an SD set top box (VCR, older cable box, low end digital-to-analog converter).)
Dec 19, 2013 | Televison & Video
Just bought a vew 65 inch LED toshiba and it says digital channel signal is weak. Why
Make sure you have the menu set on digital channels not cable. Set antenna to air to pickup digital hd channels.
Nov 27, 2011 | Televison & Video
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Dec 06, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
DTV converter box
Buy a hdtv antenna to autoscan program channels which should bring in a lot more then reconnect with the older antenna afterwards and if you're still not getting all the channels then each source needs a strong hdtv antenna that can be adjusted manually.
Oct 18, 2008 | Insignia Digital-to-Analog Converter for...
Media Center can't find digital TV channels for TV Wonder HD 600
Just to make sure, you do have analog tuners setup right?  Media Center 2005 requires analog tuners be working before digital tuners are allowed.
Oct 11, 2008 | ATI TV Wonder HD 600 PCI PC TV Tuner...
LG Electronics - 42LD340H - 42 Inch Tv Widescreen Logo
60 people viewed this question
Computer Repairing
Computer Repairing
