Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
My ipod says www.apple.com/support/ipod - Apple 20gb Ipod Mp3 Player With Click Wheel System
    Problem Solver:
  • 7 Answers
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
could be just your hard drive cable
Posted on Jun 28, 2009
  • 342 Answers
Go to youtube.com and type in sad face icon fix. There is a free video on solving this issue
Posted on Jun 24, 2009
4 Suggested Answers
PyroPCMan
  • 405 Answers
SOURCE: apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Posted on Apr 03, 2008
SOURCE: my ipod says www.apple.com/support/ipod
Guys, if you have the ipod photo, I used to get the hard drive locking up , which would bring up the www.apple.com/support/ipod screen.
WHen you try to start it up, put the ipod to your ear and listen to hear if the hard drive is stuck-ie if you can hear the drive repeating a clicking noise, then it is stuck.
If it does this, hit the ipod with an open hand (like a slap). No joke. This is for real. Slap it a couple of times and then try to restart it. If it doens't work the first time, try it again. SOmetimes it works first go, sometimes it takes a few, but eventually it does work.
It seems like the hardware inside is stuck for some reason and slapping it fixes the problem.
My ipod has locked up about 5 or 6 times and each time it has worked for me.
Give it a go. Don't pay apple to get it fixed. They probably do the same thing and charge you hundreds for it.
Posted on Oct 04, 2008
  • 10 Answers
SOURCE: i turn the ipod on an it keeps on showing the
You need to restore your iPod from Disk mode:
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
  6. Open iTunes.
  7. After a few moments, your iPod will appear in the Source panel in iTunes.
  8. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  9. Click Restore.
Hope that helps.
Cheers.
Posted on Jan 03, 2011
My ipod says www.apple.com/support/ipod when i turn on my 160gb ipod it reads a big red x and the apple.com/support
This indicates that the hard drive inside the iPod classic has gone bad.
Check Apple's Warranty web page to see if your iPod is still under warranty: https://selfsolve.apple.com/GetWarranty.do
Simply type in the Serial Number located on the back of the iPod, and your location. Who knows, if you are lucky, you may be able to send it in to get it fixed/replaced for free.
May 27, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Ipod not working
hey, give a try to this
http://www.apple.com/support/ipod/five_rs/
select your model and follow the steps.
If it doesnt solve your problem, drop me a line.
Mar 16, 2008 | Apple iPod 4th Generation MP3 Player
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
329 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
