Question about Phonak ComPilot
Power light does light unit will not turn on - Phonak ComPilot
Blinkin light
Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
Mar 31, 2014 | Daikin Mini Split Ceiling Suspended Units
LMS 520c back light not working
the light switch is in the power up button...turn the unit on let it boot up then push power button to set light as you want it do not hold down power button that will just turn unit off.. push the power button just one time if you want light brighter push till you get the back light you want
Jan 21, 2014 | Lowrance Lms 520c 5" Screen Color External...
Unit will not turn on
Press the power button down for 10aeconds, then release and try to turn on again.
Jan 17, 2014 | Microsoft Surface RT
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
May 26, 2012 | Sony MHC-RG222 CD Shelf System
When you turn it on The blue light flashes and it returns to the red light and will not turn on
This is a power problem from the unit. The unit receives power into it but does not supply the power sufficiently enough to get the unit to function well. This is why the blue light flashes when the initial burst of power is sent into the unit but due to lack of follow up power the unit fails to remain on.
Best get an expert to identify if the power supply distributor in the unit is bad or the ic which is responsible for the distribution is the cause.
Hope this solution has been helpful?
Apr 10, 2011 | RCA RT2870 Theater System
Red light comes on but the unit wount turn on
The red light is associated with the memory (constant 12 volt power). You also need switched 12 volt power (power with key turned to accessory)for the unit to turn on. If you installed the system yourself, you are looking for 12 volts on the red wire of the Jensen unit. If power exists at the unit, check the fuse of the unit and the fuse of the vehcile.
Feb 03, 2011 | Jensen Vm9214 Car Video Player
Power to unit but will not turn on.
You need to replace your STKs Both of them they are convergence ICs and do control startup. they are big black ics STK392-040 also ck (2) resistors-- RZ142 3.9ohms RZ145 3.9ohms .To order Parts Call Electronix 1-800-223-3205.
Dec 30, 2008 | Samsung HCN529W 52" Rear Projection...
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Apr 07, 2008 | Mitsubishi WS-55515 55" Rear Projection...
No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Oct 04, 2007 | Cyberhome CH-DVD 300 DVD Player
Phonak ComPilot Logo
24 people viewed this question
Top Phonak Cell Phones Experts
Vladimir Frolov
Brett Duxbury
Brett Duxbury
 Mikey
Mikey
Are you a Phonak Cell Phone Expert? Answer questions, earn points and help others
