Question about Watches
Set manual tensity watch - Watches
Setting my skmei skm1155 watch
Try Googling (skmei)(skm1155)(manual) without parens.
May 20, 2017 | The Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
How to set a casio aw817av watch
Hello Kenneth,
Here is the manual for your "st*pid" watch.. lol
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Yes, you are right, it is not a simple watch to set. But with that manual, you can just follw the instructions.
The manual is in PDF format, if you can't open it download and install adobe reader (free)
You can rate my answer if this helped you.
Nov 11, 2011 | Casio AW817AV Wrist Watch for Men
Got mine yesterday and its set on eastern time zone, i need pacific time zone and it will not sync, how to manually adjust ime
You should be able to set your watch to the Pacific time zone.
f you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
You shouldbe able to find the setting method in the manual.
May 12, 2010 | Casio Atomic Timekeeping WV58A 9AV Watch
Amw 702 watch casio fishing watch set up problems
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 13, 2010 | Casio Fishing Gear Watch
HOW TO SET THE HANDS ON A Casio AW81D-7AV WATCH
To get a full set of instructions go to the Casio web site (put "casio watches" and choose the casio web site).
Select "support"
Select "manuals"
Select "watches"
select "watch manual archive"
Put your watch number in the box and click on "search"
Jan 13, 2010 | Casio Unisex Watch AW81D-7AV
CYBEAT W.R.3BAR WATCH MANUAL
i have a cybeat watch,the manual is in japenese i need it in english
Dec 29, 2009 | Watches
Setting watch after battery replacement unable to set watch
Make it as big as you need.
Hope this tip helps
R/
David
Dec 26, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Setting time on casio illuminator watch
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Dec 03, 2007 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
99 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
