Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
My engine runs fine, but when engaging mower deck, mower shutters and emits black smoke from engine, and loses power....still turns blades, but not fast enough to cut grass
  • Anonymous Mar 12, 2014
    i have a ransome 728 all has been fine yet now mower deck won't engage???
  • 378 Answers
Check your fuel pump. Fuel pump problem.
Posted on Jun 14, 2009
Engine seems to run fine but when pto is engaged engine loses power
whatever the pto is hooked to,is putting pressure on it and slowing it down,if its a deck,then the spindles are bad or binding,blades need to turn freely
Jul 11, 2015 | Garden
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
Husqvarna riding mower smokes when cranked and dies when engaging blades
If it dies when engaging the blades it's not getting enough juice to do so. Test the battery and make sure you are getting at least 12 volts. If not, charge it. If so, the solonid is going bad.
Apr 13, 2017 | Husqvarna Garden
MTD J/130
check the oil and see if it smells like gas if so the needle valve in the carb is bad
May 09, 2012 | Garden
When I lower the mowing deck on my Murray 17.5hp riding mower white smoke pours out and it dies. The engine runs fine until the deck is lowered.
Does it make a squealing noise then too? The white smoke is probably a belt burning up. Either you have a locked up blade spindle, or the belt is off, and rubbing. Check the deck belt(s) and the clutch assembly.
Aug 02, 2010 | Garden
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine slows down with blades are engaged?
sounds like the blade spindles are binding, many have Zerk fittings to grease them. with belt disengaged try turning the pulleys they should turn easily and have no wobble in them. if either is wrong replace spindle and best to change in sets. this is the most common issue.
Apr 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawnmower loses power when I engage blades
This is most likely a belt problem. Check the deck drive belt that runs from the mower deck to the engine it/s come loose and got stuck between the guides.
Mar 15, 2009 | Garden
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
600 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
