Question about 2000 Mercedes-Benz CLK-Class - Coupe - Weathershield HP Car Cover
Only dashes are shown when trying to put radio code in
Battery was diconneted when tried to put code it come up 7 SFFE its a 520 blaupunkt radio cd
you would be surprised how many error code you can find by putting the word error code followed by the actual code into google
Dec 16, 2014 | Blaupunkt Car Audio & Video
Reset code mitsubishi car radio
Try using this code 8201 and when all four digits are displayed push either the tape or cd button and that should be it..
Hope that helps.........
Sep 12, 2008 | 1997 Mitsubishi Montero
Putting in the code on a 1999 E280 10 stacker radio
my radio wont come on. on the dash under audio there are 5 to 6 dashes underneath the word audio. dose that mean that I need to add a code number to those dashes and how do I do so ?
Oct 05, 2013 | 1999 Mercedes-Benz E-Class
I have just put a new battery in my 1992 3.1i8 BMW and consequently reset the radio. It has locked in 3 dashes and I can't enter any numbers in. Any help would be greatly appreciated!
If you do not have the book for the radio, I believe there is a trick to entering the code. Its not just using the numbers. I think you have to hold another button down while entering the code or use the station up down button to enter the code. Try hitting all the buttons one at a time and see if that enters anything on the desplay.
Jan 30, 2013 | Cars & Trucks
How do i remove the factory radio on my 1983 cadillac fleetwood
Locate and remove two (2) phillips screws that secure the top of the plastic panel that surrounds the radio. The plastic dash panel will pull off once the screws are removed as shown in the photo above.
The front of the radio is held in with two (2) 7mm bolt screws at the top of the radio. Remove the 2 bolt screws.
There is a hidden radio that secures the rear of the radio and is located under the radio. Pull the ashtray to its extended position. You will need to lay on your back or side and look behind the ashtray, up to the bottom of the radio.
Once the ashtray has been pull to its extended position, you should be able to locate and remove one (1) 7mm bolt screw as seen in the photo above.
Once all screws have been removed, the radio can then be removed. Pull firmly on the radio to remove it from the dash. The radio will most likely resist pulling from the dash. The antenna cable which plugs into the rear of the radio is very short and gives the radio resistance when trying to pull the radio out of the dash. Continue to pull firmly and the antenna cable will unplug itself as the radio is pulled from the dash.
Unplug (1) blue, (1) white, and (1) black wire harness connector(s) from the rear of the radio. There will also be wires extending from the rear of the radio with a plastic connector attached to the wires about 4 inches from the rear of the radio. Unplug this small connector. The radio can now be completely removed from the dash. Set it aside. You will need to remove the plastic brackets attached to the top and bottom of the GM radio. This will be shown in detail in the "Mount New Radio" section.
Hope these helps....
Jan 23, 2011 | Cadillac Fleetwood Cars & Trucks
Need radio code for Chevy venture 2003
radioo
02-20-2006, 02:03 PM
Only a GM dealer can unlock the radio.
It is much smarter to disable lockout entirely, with MP3/WMA, DVD and XM-ready stereos, the regular CD, cassette, and radio-only units aren't so hot.
The following applies to an unlocked powered-on radio (2000 shown)
1. Do not disconnect the battery
2. Press the stereo's "1" and "4" buttons at the same time for five seconds with the ignition on and radio power off. he display will show "SEC", showing anti-theft is on
3. Press the MN button, the display will show "000"
4. Press the MN button until he last two numbers are the same as your secret code (how do you find this? you decide the code?)
5. Press HR until the first one or two numbers displayed match your code. The numbers will be displayed as entered.
6. Press "AM/FM", if the display shows "_ _ _ " you have disabled Theftlock, if "SEC" is shown, it is still in Theftlock
01-30-2010, 02:14 AM
I just tried this for my 1998 Chevy Venture and it works! press the 2 & 3 numbers at the same time for about 10 seconds; a 2 or 3 digit code will come up; press the am/fm button for about 10 seconds; another code will appear; dial 1-800-537-5140 and enter 106010 followed by the # sign; enter the 4 or 6 digit code from your radio followed by an *; the phone number will give you a 3 or 4 digit override code; enter this code into your radio just as your owners manual tells you to - use the hour and minute buttons to put in the unlock code, Press AM/FM button, "SEC"---" will display and You can turn on the radio. I had tried this with another dealer code and it wouldnt work, but with the 106010 dealer code it worked just fine, my unloc code was 0120
Jan 21, 2011 | Car Audio & Video
I have the code for the radio but don't know how to put it in to make the radio work. mITSUBISHI mAGNA 2005
ok you will have to take off ur dash and puyll out your radio unpluge it and plug the new radio put it back in and put the dash back in
Dec 21, 2010 | Mitsubishi Car Audio & Video
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
Megan Radio Codes
you can only put the code in if 4 zeros are shown if there are 4 dashes leave the radio on till the 4 zeros show can take over an hour then using the remote next to the steering wheel r/h side use the wheel to move the number up/down to the right number then press the button on the bottem to move to the next number after all numbers press and hold the bottom button to enter the code
Sep 02, 2009 | 2000 Renault 181
Cant put the code in
===================================Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [¬ ] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [¬ ] button for up to 10 seconds to store the code
Feb 20, 2009 | 2000 Renault 181
2000 Mercedes-Benz CLK-Class - Coupe - Weathershield HP Car Cover Logo
11 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
 Ronnie
Ronnie
Level 1 Expert
ptpumpman
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
