Question about GE Profile 28.5 cu. ft. French-Door Bottom Freezer Refrigerator PFSS9PKY
How to reset display on pfss9pky - GE Profile 28.5 cu. ft. French-Door Bottom Freezer Refrigerator PFSS9PKY
98 Oldsmobile Aurora There's a on my Dash it says information center and has the oil fuel speed all that it says low oil is there any way anybody knows how to reset that
Check your engine oil using the oil dipstick located on the engine - you need to add oil to the fill line as shown on the dipstick. You should have the oil replaced regularly (every 3-6 months) and keep your eye on the level if the engine is leaking oil underneath or burning a lot of it.
Mar 08, 2017 | Oldsmobile Cars & Trucks
Ford explorer trac 2007 change the oil and filter and now have a wrench light on ,how resolve the problem
Sounds like you need to reset your Oil life/ maintenance reminder light. (also, double check your oil level)
To reset Oil life on a standard dash stlye:
1. pres and release the TRIP/RESET button until the message center displays SETUP MENU HOLD RESET
2. Press and hold the TRIP/RESET button for 2 seconds until the message center displays RESET FOR SYS CHECK
3. press and hold the TRIP/RESET button for 2 seconds until the message center displays OIL LIFE xx% RESET IF NEW
4. Press and release the TRIP/RESET button until the message center displays HOLD RESET IF NEW OIL
5. Press and hold TRIP/RESET button for 2 seconds and release to reset oil life to 100%
6. Message center will briefly display OIL CHANGE SET TO 100%
With a message center cluster the procedure is as follows:
1. press and release SETUP button until message center displays PRESS RESET TO BEGIN SYSTEM CHECK
2. Press and release RESET button until the message center displays HOLD RESET IF NEW OIL
3. Press and hold RESET button for 2 seconds and release to reset the oil life to 100%
4. The message center displays SETUP MENU HOLD RESET
Hope this is what you need/ are looking for. Goodluck & let me know how it goes, or if you have a different problem.
Nov 03, 2013 | 2006 Ford Explorer
Filter light will not turn off
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Nov 11, 2012 | GE PFSS9PKy Refrirator
How do I get the "change oil" message off my 2008 f 450 superduty?
Message center cluster
#1 press and release setup button until mess. cntr. displays"press reset to begin system check"
#2press and release reset button until cntr. displays"hold reset if new oil"
#3press and hold reset button for 2 sec. and release oil life should read 100%
#4 center displays"setup menu hold reset"
base cluster
#1 press and release trip/reset button until mess. cntr. displays"setup menu hold reset"
#2press and hold trip/reset button 2 sec. until mess cntr. displays"reset for system check"
#3 press and hold trip/reset button 2sec. until mess. cntr. displays"oil life XX% reset if new"
#4 press and release trip/reset button until mess.cntr.displays"hold reset if new oil"
#5 press and hold trip/reset button for 2 sec.and release to reset to 100%
#6 mess. cntr. breifly displays oil change set to 100%.
HOPE THIS HELPS
Feb 10, 2010 | 2008 Ford F 250 Super Duty 4WD
After an oil change the change oil light remains on
Press the setup button until "press reset at oil change" is displayed.
Then press and Release reset button until "hold reset to confirm" is displayed.
Now press and Hold reset button until "oil life set to 100%" is displayed.
Apr 13, 2009 | 2005 Ford Five Hundred
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 19, 2009 | 2000 Volkswagen Golf
GE Profile 28.5 cu. ft. French-Door Bottom Freezer Refrigerator PFSS9PKY Logo
81 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
