Question about Air Tools & Compressors
Slip clutch on 1015 case blind header - Air Tools & Compressors
Is there a place to add transmission fluid to a 2002 kia sport age clutch, mine is slipping
no transmission fluid in a clutch system
only brake fluid
and that is in the reservoir at the top of the clutch master cylinder or shared with the brake master cylinder
if the clutch is slipping it indicates the need to replace the clutch master cylinder or tor replace the clutch assembly
Clutch master cylinder is cheaper and easier and is generally the main reason for slipping clutches unless you have a cable clutch in which case replace the cable
May 27, 2017 | Kia Cars & Trucks
What cause a the transmission to slipp an not go into drive are reverse ?
The clutch likely needs to be replaced.
Its a hydraulic system if somehow air got into the system it wouldn't shift to good but the clutch wouldn't slip because that would create a disengage problem..
Clutch slip is not engaging but would cause some shifting issues do to grab then slip condition.
How many miles are on the clutch.
May 16, 2016 | 1996 Ford Explorer
My power window will not work is there a fuse that controls all windows
There is a fuse for windows. However, if only one window is non operational, there is either a short specifically affecting that window or the motor for the window is broken.
Dec 08, 2015 | 1996 Jeep Grand Cherokee
Clutch is slipping
That is a bit like asking how long is this piece of string in my pocket?
You give no vehicle details or history so the answer must be generic. Clutches can slip if they are maladjusted and don't have working clearance. Some adjust automatically and some need periodic adjustment.
Clutches can slip if they are heavily contaminated with oil and so if that is the case discovering and rectifying the leak must be part of the repair. In all other cases clutch slip is caused by simple wear and tear or because of weak or broken springs.
In almost all cases access is gained to the clutch by removing the gearbox. There are a few exceptions.
Removing the gearbox of some models is simple and straightforward and other models difficult and complicated requiring much dismantling.
Mar 03, 2015 | Cars & Trucks
What causes my clutch to slip first time I use the car each day?
clutch slip the first few operations especially in cold weather indicates that the clutch fluid is very dirty or the clutch master cylinder compensating port is blocking up. If it is a cable clutch then the cable is dry and tending to stick in the outer case . in that case replace the cable.
Feb 12, 2015 | Cars & Trucks
Slipping transmission in a vw beetle 2001
Gear-shift or auto? In either case it's a slipping clutch! In the case of a stick shift it's either a wrongly adjusted clutch setting; or a worn-out clutch centre-plate or faulty cover. If it's an auto, you have big bother and will need the help of a gearbox specialist.
Apr 23, 2014 | Vehicle Parts & Accessories
What is Bcc & cc for..?
Cc stands for carbon copy which means that whose address appears after the Cc: header would receive a copy of the message. Also, the Cc header would also appear inside the header of the received message. Bcc stands for blind carbon copy which is similar to that of Cc except that the Email address of the recipients specified in this field do not appear in the received message header and the recipients in the To or Cc fields will not know that a copy sent to these address.
Jan 14, 2011 | Computers & Internet
2000kia sophia clutch slips
If it's slipping it's near the end of its life and you'll have to change it. Make sure to inspect the rear main seal - most of the time a clutch slips because of wear but a rear main seal leak will allow oil to leak onto the disc and it'll slip. In either case you'll need a new clutch but if the seal is leaking it'll ruin the new one too.
Feb 26, 2010 | 2000 Kia Sephia
Benelli 900 sei
Dear Sir. The engine oil flows through the starter clutch which acts as a centrfugal oil filter. Sludge builds up and causes the starter clutch to slip.
It is possible to replace the Benelli 900 starter clutch without having to remove the engine.
It requires removing the clutch, then the side casing and gears. The sump needs to be removed...middle exhauster header pipes first. The lh engine cover and oil pump also needs to be removed. The primary drive shaft can then be removed from the RHS of the engine. the primary drive chain and satrer clutch assembly will now drop enough to enable the removal of the sprocket from the starter clutch (it is a bit tight and then the rest of the starter clutch will come out of the chain. Be aware that the oil pump drive connector is on the end of the primary drive shaft and care needs to be exercised. This is possible if due caution and care is taken. Assembly id basically reverse of above. Happy fixing.
Mar 31, 2009 | 1982 Benelli 900 Sei
Tune up
Slipping tranny can be caused by that. Rule of fixing cars is if not sure start cheap. Replace the Filter and fluid. Also it wont hurt to put in Lucas Transmission Additive with the fluid change. Change plug 2 ways if it has motor mounts on top then disconnect them and pull the engine foward. or
No need to rotate engine as I was told that sometimes this causes damage to exhaust link which is flex. First two plugs can be reached by going along the same channel as exhaust pipe from header runs. Last plug remove right side tire and you can reach up by body to change it. This one is blind, but it's possible.
Oct 23, 2008 | 2000 Pontiac Montana
Air Tools & Compressors Logo
66 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
