Question about Casio FX-115ES Scientific Calculator
How to take calculator off SCI mode - Casio FX-115ES Scientific Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Press SHIFT SETUP then select one of the Fix or Norm modes.
Posted on Apr 15, 2014
How to cancel fix mode
If your calculator has a mode key, try pressing it repeatedly and see what is displayed. If you see FIX, SCI, ENG, Float or NORM, press the key corresponding to float or Norm (if there is no float).
If your calculator has a key next to which is the FIX marking, look around to see if you can find SCI, ENG, Float or NORM. Select Float or Norm
Jul 30, 2012 | Office Equipment & Supplies
I want to remove rad and sci symbol from casio fx-901 calculator display
For removing SCI symbol press following keys Shift-->Mode-->8-->1.
You can't remove RAD symbol, you can only replace it by DEG or GRA.
Aug 22, 2011 | Casio FX-115ES Scientific Calculator
How can i get fix off my calulator
To get out of the fixed decimal mode, press the MODE key until you see the screen giving you the three options "Fix", "Sci", and "Norm". Select Norm 1 or Norm 2. If you select a Sci mode, you'll get "SCI" on the screen in place of the "FIX".
Jun 23, 2011 | Casio FX-300MS Calculator
HOW CAN I GET FIX AND REG OF MY CALULATOR.I AM USING FX 300MS.
Press MODE 1 to get out of the regression mode and into the standard calculation mode.
Jun 23, 2011 | Cameras
I just wanted to know if there is an engineering key or function like sci on the fx115 es casio calculator
SHIFT MODE 7 for SCI and SHIFT MODE 8 for ENG. Each of them needs to be followed by a digit.
Mar 02, 2010 | Casio FX-115ES Scientific Calculator
How to get it out of Sci math
To get out of the default MthIO press [SHIFT][MODE][2:LineIO]
To get out of Sci display format, press [SHIFT][MODE][6:Fix] followed by a number between 0 and 9, that will set the number of decimal digits.
Hope it helps.
Thank you for rating this solution.
Dec 04, 2009 | Casio fx-300ES Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
How to switch off the REG and Sci function
press MODE then select CALC then COMP to remove REG.
press MODE again select DISP then NORM1 to remove SCI.
May 20, 2009 | Casio FX-115W Plus Calculator
Turn off sci
To turn off SCI, press the MODE button, then press 9. MODE 9 is the function for NORM, which means normal use. DEG is always on, but if you want to clear SCI or FIX, MODE 9 will clear these.
Nov 19, 2008 | Casio FX-250HC Calculator
Problem withi scientific calculator
How do I get rid of the word "Fix" from the calculator display.
Jul 25, 2008 | Office Equipment & Supplies
Casio FX-115ES Scientific Calculator Logo
16 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
