Question about Dishwashers
Drain My dishwasher wont drain the wather inside. it rinses with the dirty water and even at the end of cycle it doesnt drain.
  • Dberentson Dec 03, 2007
    Same problem for me. It's rinsing with dirty water and doesn't completely drain. It's a built in Bosch purchased 5 years ago.
  • bbopbev54 Feb 06, 2008
    my dishwasher wont drain after the wash cycle. We have a new garbage disposal if that makes any difference. I pulled the drain hose off disposal to see if it was clogged. It wasn't. I removed the screen inside to see if it had something clogging it from the inside. It was clean.
Don't buy this brand anymore, and be sure all your friends know not to also. I have a GE, GSD4000J, it is less than 2 years old, I have used it maybe at most 6 times. Now it will not drain, washes with the same water, does a terrible job of washing. I own a remodeling service, I will never buy GE products for any of my jobs from this day forward. Have not been able to get any help from GE, they don't seem to stand behind their products at all, or care about their customers once you have bought their products.
Posted on Nov 07, 2007
  • 27 Answers
What brand of dishwasher do you have? (model#?)
have you recently installed a new garbage disposal?
Posted on Nov 01, 2007
Kitchenaid dishwasher wont drain. Drain hose has been snaked clear. Attachment to Disposal is clear. Hose is not kinked. Dismantled pump area inside washer and cleared all debris. Still wont pump out water...
If the cycles of the program are working accordingly then the most important thing that must be done is to CHECK and MEASURE the VOLTAGE at the DRAIN PUMP when the machine is in the rinse cycle.
If there is no voltage then the program controller is faulty. If there is voltage then the pump is defective. You can test the pump using a meultimeter or power it externally
Oct 06, 2011 | Dishwashers
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
Water wont pump out at end of cycle
it would be helpful to have the full model number of the dishwasher.
do you get any lights flashing? how do you know it is end of cycle? could be still in wash and not got to rinse at all. Do you hear the drain motor running?
Try with a shorter cycle like simple rinse only and see if it drains the water.
I am assuming you have checked the filters are clean and there is no blockage in the kitchen drain.
Jan 10, 2011 | GE Dishwashers
Dishwasher wont drain after rinse cycle . Moffat Quiet One
My dishwasher runs but just does not clean and leaves food particles all over like its not getting clean water to it. I cleaned the passages of any food from the top end. Any suggestions. Its a moffit MLD4007l20ww
Feb 20, 2010 | Dishwashers
Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
273 people viewed this question
Top Dishwashers Experts
