Question about Home
Change battery on globe clock - Home
I own a 2008 holden statesman and i have a problem with headlight globes. Every time i change the globe its always dull i have tried cheap ebay globes right up to $300 h.i.d kits and still dull
Hi Michael The issue you have sounds more like a power/earth supply issue. I'm assuming the light lense and reflectors are in good order. The battery is good and no issues with the charging system. Start with the easy side earth or ground side. Connect a seperate earth from light to battery earth terminal just for test purpose. If light is improved then do the same the otherside. if good then you have an earthing problem.(use a slightly heavier gauge wire than your nomal lighting wire so there is no voltage drop). If no different move to power side disconnect connector to globe check and be sure which is the live terminal on the globe and connect a wire as before from + terminal on battery to positive on globe, light must be bright now. Ist check for loose or burnt terminals ie at connection to globe, battery power/ earth terminals.Check Battery to chassis connections for tightness. If easy to do so remove and and clean an re secure. Check engine to battery/chassis connections if all good you have to move onto the supply from fuse box and any connetions in between this is where it becomes more involved and would advise a qualified person to investigate. good luck
Jun 15, 2017 | Holden Cars & Trucks
Setup wrong language what do i need to do change language from german to english
Go to the control panel and look for clock, language, and region. It will have a picture of a clock and a globe as it's icon.
Sep 08, 2011 | ASUS Eee 4G Notebook
I WANT TO CHANGE TO ENGLISH
Hello there,
5. Change Format to English, Apply and Ok pcsyke_57.jpg 6. It's up to you if you want to change the Location.
Hopefully this helps. Thank you for posting.
Jul 08, 2011 | Computers & Internet
I have MSI Wind U100-280US 10-inch Netbook that its language is hebrew. how can i change it into english version of windows. because i bought it i israel. i cant understand its language popups,start menu,...
You need to do the following:
If it's windows 7, Go to the windows button, click it and then click on control panel (the first menu item in the third section of the grey panel). In this part you'll see an icon with a globe and a clock. This is the Clock, Language and Region section. Click on it and that will bring you to the detailed settings, with three icons: a clock and calendar, a clock and globe and just a globe.
Click on the clock and globe to access the region and language settings. The first drop down menu is the language setting, which you should change to English (United States)
Hope this helps.
May 17, 2011 | MSI Wind U100-280US Netbook
Change light bulb in night light for Hello Kitty LED Digital alarm clock, Model NL-HKC 206
You lift the Kitty up off of the base and take a butter knife and gently push on the plastic prong on the inside. It is held in place by 4 prongs. The plastic kitty should come right off and there is a small globe that has one screw. Unscrew the globe and replace the light. The light is super small so you might want to go to the store after you have the light bulb out. Hope this helps!! :-)
Feb 20, 2011 | Spectra Hello Kitty Digital Alarm Clock &...
Current language is italian how to change the language to english
presume your using windows, go to control panel, region and language. (looks like a globe with a clock in win 7) and change it there
Feb 02, 2011 | Acer Aspire 3610 (3618AWLMi) PC Notebook
Changing the brake light bulbs
Have you had a look from inside your boot? I could imagine its covered over with carpet but if you take off the boot wall/carpet and feel around you should find the wires which come out of the rear of the Lens which house the globes. Then you usually twist anti clock slightly (not a screw) to remove globe holder which has globe in it. Or there can sometimes be a wire spring holding the globe holder into the back of the lens. Im pretty sure it takes a bayonetglobe 5W. 47207.
Feb 09, 2010 | 2002 Audi A4
I changed the batteries in my olympia globe and cannot call up the CD list. The only message I get is"olympia globe.
After I changed the batteries, waiting for about one hour, the CD list finally came up and after a time, I was able to get the CD list to reappear and arrow down to "date and time".
I don't understand how it got well but I'm happy.
Jan 11, 2009 | Olympia InfoGlobe Caller ID
Clock
you need to change your backlight globes, they are just little wedge globes behind the clock
easy
Sep 11, 2008 | 1991 Lexus LS 400
Home Logo
21 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
