Question about Car Audio & Video
Screen on advent ohyson1 turns on and off by itself
Why does my laptop turn itself off after i enter the settings f2 or f12
You cannot do this without installing an operating system first on the hard drive, that has the drivers for the advent laptop you are using.
It switches off because it cannot find the windows operating system.
Try and download a free copy of knoppix (Linux) to run from the CD/DVD drive to see what is on your hard drive.
KNOPPIX Live Linux Filesystem On CD
It will give you a windows like environment to use the laptop.
Mar 18, 2015 | Advent Computers & Internet
What does df mean and what do i do about it
www.advent-air.com/advent-furnace-thermostat.htm
Jul 05, 2014 | Advent Analog Wall Thermostat
On my advent roma 2000 laptop, randomly the screen went black when i turn it on but it comes on at the start for 2 seconds then goes off..? what do i do
its overheating,check whether your fan is working, otherwise open it and clean it out, do not use a blower, the spinning fan can overcharge your motherboard and blow it
Oct 23, 2012 | Advent Computers & Internet
Advent 7111 narrow screen
If the display isn't going full screen, on that 15.4 inch TFT LCD screen, the problem is the screen Inverter, or LCD screen itself.
90 PERCENT OF THE TIME the fault is the screen Inverter.
It isn't a simple screen resolution setting that needs to be changed.
http://www.laptoppowerjacks.co.uk/advent-inverter/advent-7111-7107-8315-lcd-screen-inverter-as023217127-iv09140t-lf.html
Primer:
An LCD screen does not produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
It needs an additional light source.
The additional light source is a Backlight.
A Backlight can be a CCFL, or a series of LED's.
The Advent 7111 Notebook PC uses One CCFL,
http://www.screencountry.com/index.php?section=products&model=7111&brand=Advent&size=
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick. Length is almost as long, as the LCD screen is in height. 2mm is close to 1/16th of an Inch )
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Primer over.
I don't have access to a Service Manual, for the Advent 7111 Notebook PC. I haven't had one come to my shop for repair.
I DO have years of experience at repairing laptops, and I see the Advent 7111 is just a basic laptop, as I HAVE repaired over the years.
If you wish, I can guide you step by step, in replacing the screen Inverter.
(MANY people go out, and buy an LCD screen, when the problem is a much less expensive screen Inverter. Afterwards they buy the screen Inverter. Too bad they didn't come here first)
Post back in a Comment.
Regards,
joecoolvette
[ The Advent 7111 Notebook PC is just a re-badged Quanta TW3M.
According to the source, you should see TW3M on the bottom of the laptop.
http://www.uktsupport.co.uk/advent/laptop/7111.htm
May 20, 2012 | Advent Computers & Internet
Advent rebooting on its own
Check your bios to see if there is a hard drive option for compatability mode, you should change this value perhaps. What are your options in your bios?
May 16, 2012 | Advent Computers & Internet
The on screen volume bar has disappeared.
Try this free app as a replacement:http://www.softarium.com/soundvolumehotkeys/
Apr 11, 2012 | Advent Computers & Internet
Hi, i have a Advent 3001 roma laptop, unfortunatly i dropped it this morning and the battery fell out, after replacing the battery and turning it back on the screen is very dark, i can only barely see the...
sounds like the light bulb inside the LCD screen broke its hair thin and very fragile will have to replace screen could be more expansive than a new laptop.
Mar 01, 2011 | Advent Computers & Internet
My screen on the advent roma 1000 goes dark
The usual culprits are loose connections (this only happens when the lid is moved forwards or backwards). The other is the LCD inverter getting too hot.
In both cases you will need to disassemble the laptop lid to check the leads and the inverter itself for dry joints.
If you're not comfortable with disassembling the laptop yourself then i recommend that you take it to a reputable repair store to have it looked at.
Regards.
Apr 12, 2010 | Computers & Internet
Advent 7098 faulty screen?
Angle the screen to the light. If you can see a faint screen image then it's probable that the backlight's inverter has either failed, it's cable has become damaged or the backlight has failed. Both of these can be tricky to replace unless you have the right tools, but can be done provided you can get a spare. Usually it's a tech job.
If the image is not there then it's either the screen itself, the graphics chip or, more likely, the ribbon cable that connects the screen to the motherboard.
You can rule out the graphics chip by plugging the laptop into a monitor.
Of course, the ultimate problem is that you've bought an Advent laptop! And most techs agree that Advent produce the worst laptops in the world. :(
Jun 07, 2009 | Computers & Internet
I have an advent 7204 with phoenix no password
hi,      its an common prob,, wen pc s turned on ane off, it actually sets up an password itself which you havent set up'd earlier,. its recommended to boot ur os,. thank you,..
Mar 11, 2009 | Computers & Internet
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
