Question about LG N1A1 Super Multi Network Storage Server
Device not detected by nas detector and not accessible by IP address
I have a linksys efg 250 nas that I am trying to access. Can I get some advice on what to try next?
so you have 192.168.1.77 as the default ip address and 255.255.255.0 as the subnet mask.
What Ip address does the computer you are trying to ping have is it in the range of 192.168.1.2 to 192.168.1.76 in the dos prompt and what is its subnet mask ?
type in ipconfig
what is the equipment between the p.c and the EFG250
what connects it to the network ? A switch are cisco vlans involved or cisco port filtering ?
Dec 03, 2015 | Linksys new networking accessory efg250...
Port Forwarding Instructions
I would suggest setting a static IP on the NAS within the subnet you have. Then log into the ip for the modem and use the web interface from the modem to configure. Dependant on which area in the settings (either NAT or firewall configuration), Look for Virtual Servers option. You should then be able to set your port forwarding for what services you wish to use. Word of warning I would suggest also using the user creation function in the NAS so users will have to authenticate before gaining access. Many of the new NAS devices have the functionality to use Active Directory/LDAP for authentication.
Aug 04, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
NAS Disconnecting from Network
I hope the brothers who has a program Printer Definition "murtec mfx 2010" Windows 7 download link here Vlada graciously
Mar 10, 2014 | LaCie d2 Network v.2 - 3TB
I have HP HDX-18 laptop, Windows 7 Ultimate installed I installed Segate BlackArmor WS 110 on the PC The IPv4 Address :192.168.0.199 IPv4 DNS Server :192.168.0.1 I used: Programs...
I'm assuming the IP address of 192.168.0.199 is actually that of the computer you are using and not that of the Seagate. You need to determine the address of the Seagate, download this: PortScan
Unzip and run it. Start address is 192.168.0.1, end address is 192.168.0.255 (it should automatically detect this). The scan will display a list of all the devices connected to your network and attempt to display what it is. Locate the Seagate and enter its IP in the text box.
Mar 07, 2017 | Seagate BlackArmor NAS 110...
Windows vista is not detecting lacie network space 2 i am trying to install a lacie network space 2 (1T) on a home network. i use windows vista icw avg free virus software. i installed the latest...
In your office network, for sure, you have a DHCP server who gave the IP addresses to all devices for that network and this seems to be the reason for why you could see your NAS. On home, you also need a DHCP server. You don't say anything about you home network. The best idea is to just make a temporary network with 2 devices: your computer and your NAS by connecting the NAS directly to your computer's network adapter, set the IPV4 IP for that adapter to the same class addresses as your NAS was set by default (usually NAS had "192.168.x.y" where "x" could be 0, 1 or 2 "y" could be any value between 1 and 254, but mostly, 1) and try to access it via http to manage him (need a user name and a password). For NAS default address and username and password, consult NAS user manual. Access it with from your preferred browser using: \\192.168.x.y
Once you gain the control, cut off his DHCP service and tell him to accept the IP address from the network defined DHCP. (btw: one normal DHCP server is allowed on one network! Cascaded DHCP also is allowed, but it's a little bit complicated)
Jun 25, 2011 | LaCie Space 2 (301515EK) 1000 GB Network...
My Black Armor NAS keep changing its IP address and can't be accessed most of the time on the network. Hw can i fix this
Configure your network's DHCP-server to *ALWAYS* give the *SAME* IP-address to the NAS -- use the (unique) MAC-address of the NAS's network-adapter to assign a "static" or "fixed" IP-address to the NAS.
Jul 27, 2010 | Computers & Internet
I've bought the Sumvision SATA net-box NAS enclosure, installed hard drive as described, but I cannot see the web interface for setting up the device. Manual is in very bad english and suggest allocating...
There's a discussion about some problems relating to this enclosure at http://forums.ebuyer.com/showthread.php?t=24636 and you may be able to get some help from the contributors there.
Jun 27, 2009 | Computers & Internet
Cant able to access the 1tb network storage
Consider a few things that may solve the problem:
1. this is how I always like to test; shut down the NAS drive for a minute and reboot; once rebooted see if it is accessible
2. need to know the ip address of the NAS drive and make sure that ip is not blocked by your system firewall (e.g. add that ip into trusted address on the firewall program; or temporarily disable any anti-virus or firewall and see if you can access, and if you can then it is the issue of firewall),
3.unless you have customized the settings, open my computer and on the addressbar type type the ip address if you know (if it is WD Mybook World then you can also try typing \\mybookworld on the address bar); in this case also try it by temporarily disabling any anti-virus or firewall program
4. one way you can figure out the ip for your nas drive is through the router's homepage; since I don't know your router type I can't give you specific steps; but try to get onto the router's main page and see the client's list or DHCP Client's List or something similar where you should see an ip also assigned to the NAS drive which is connected to the same router.
Post the feedback what happens... we'll see... good luck !!!
Jan 09, 2009 | Western Digital My Book World Edition 1TB...
Can't assign ip configuration to NAS 208
Probably the NAS got the same IP address of the router/switch. Something like 192.168.1.1. Try changing your router default IP address to 192.168.1.3. Look for the NAS now.
Dec 22, 2007 | Computers & Internet
LG N1A1 Super Multi Network Storage Server Logo
52 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
