Question about Linksys 8-Port (SD208) 8x10/100 Mbps Networking Switch
I just need to connect 2 PCs via the Linksys 8-port switch, no internet connection. One is running XP & the other is running Vista. Both plugged into the numbered ports but I can't get the PCs to see each other.
    Scholar:
  • 59 Answers
If you are not connected to the Internet and both PC's are trusted and you want to network them. The easiest solution would be to disable the firewall on both machines since there's no need to block anything. You may also need to enable file sharing on the Vista machine under networking.If this is going to be a permanent setup and you don't plan on adding any other devices I would exchange the Switch w/ a crossover cable connected into each other to save on electricity.
Posted on Jun 15, 2009
Can't connect to wireless router
1.Ensure ethernet cord coming from modem is plugged directly into internet port of router.
2.Powercycle equipment (Unplug power from home modem and router wait 15 seconds then plug back in
3.Open Network Connections XP:Start/Run/Type ncpa.cpl
Vista/7 Start/Search bar/Type ncpa.cpl
4. A.Right click on wireless connection the connection you use with router and hit properties,
B.Uncheck Internet Protocol Version 6/ Click on Internet Protocol Version 4 and hit properties,
C.Ensure Obtain an ipaddress automatically is checked
Ensure Obain a DNS server automatically is checked as well
5.Open Command Prompt XP:Start/Run/Type cmd
Vista/7 Start/All Programs/Accessories/Right click on Command Prompt hit run as administrator.
6.Type in Command Prompt: netsh int ip reset reset.log (Hit Enter after each command)
netsh int ip delete arpcache
netsh winsock reset
ipconfig /flushdns
7.Restart Computer
8.If still unable to access internet Disable Firewalls/Antivirus
Dec 14, 2010 | Linksys Wireless-G WRT54G Router
Configure my linksys wrt120n with the cd but can't found the internet all wiring are okay
1.Powercycle your equipment (unplug) Modem and Router
2.To ensure it is setup correctly the Ethernet cable should be plugged into the Internet port of the router
3.Wait 15 seconds and plug equipment back in
4.Check Firewalls Win XP: Start/Control Panel/Firewall/Turn off not recommended and try the internet
5.XP: Go to Start/Run/Type ncpa.cpl this will bring you to Network Connections/Double Click on Connection ensure the it is assigned by DHCP and it has a valid ip address it should start with 192.168.
Vista/7 Go to Start/Search Bar/Type ncpa.cpl and hit enter, right click on connection and hit properties. Uncheck Internet Protocol Version 6 and Click on Internet Protocol Version 4 and hit Properties. Ensure that Obtain and ipaddress automatically is checked as well as Obtain a DNS service automatically and hit ok.
6.Restart computer and Try to get online
7.Go to command prompt Win XP:Start/Run/Type cmd and hit ok Vista/7 Start/All Programs/Accessories/Right click on Command Prompt and hit run as administrator.
8.Type ipconfig /release and hit enter
Then type ipconfig /renew
9. Minimize command prompt and try browser
10. If still unable to access the internet open command prompt again and type:
1.netsh int ip reset reset.log
2.netsh int ip delete arpcache
3.netsh winsock reset
4.ipconfig /flushdns and restart computer
Oct 02, 2010 | Linksys WRT120N Router
Home Computer Network Confusion
it easy plug your big plug rg 45 cable from the 2010 into your port 1 on your router then buy more rg45 cable from comp store plug it into port 2 then into comp 1 plug another one into port 3 on your router and plug it into other comp. everything should work xp will pick up and install anything needed. have fun surfing
Sep 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys wireless on my desktop,trying to use another computer in dining room that has a router or rooter dont know what it is, cant get online please help,the wireless rooter is connected to my main...
You do not need 2 routers to connect to the internet infact you need only 1. having 2 conflicts with pcs and causing them not to work.
From the wall you have your cable fro your internet that plugs into your modem, from the modem it plugs into the router by ethernet cable to the uplink slot and then your computers connect to the router. Most routers can connect 4 computers at once. If running them all wirelessly just reboot them and they should connect automatically. If your wiring them plug them into the back by an ethernet cable in the slots 1 for the first PC, 2 for the second so on and so on. You may have to cold boot everything at first meaning shut down all the computers, unplug the router and modem. Then Plug in the modem let it boot up, plug in the router let it boot up then the pcs.
If you need more hook ups if 4 isnt enough yo uneed a switch or access point not another router.
Let me know If this helps and if I can help further.
Joe
Apr 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
CONNECTIVITY PROBLEM WITH 8 PORT D-LINK SWITCH FOR MORE THAN 3 PC
First thanking to using d link switch
Tell me Your dns
and using pppoe ya proxy
KETAN PATEL
Mar 11, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Hi sir i have a problem that  how to share the individual internet connection on other pcs
To share the induvidual internet connection with other pc s you need the following:
1. The pc which owns the internet it need an ethernet connection too.
2. The other pc's which dont have internet connection it needs
3. You need an equipment which connects the internet pc and
other pcs. It called Ethernet switch.
Linksys company has a good product, which can connect 4 pc together, called linksys Wrtg54gl. It not only a small switch
it also has the capability to connect wifi devices.
Buy this router connect the pc-s to thos router with ethernet switch. You need to set up ip addresses for the pc-s.
The whole procedure is well written in the Linksys admin manual.
I hope it helps.
Here is the router manual:
ftp://ftp.linksys.com/pdf/wrt54g_ug.pdf
If you dont need the wifi router (you dont need wireless connection buy this model:
Linksys BEFSR41
If you need to connect more than 4 pc it requires a new solution.
If all pc are connected with ethernet together, you need another solution.
If you has a problem with this write to the forum, i will respond you.
Jan 09, 2009 | Microsoft Windows XP Professional With...
Switching from Linksys 5 port switch to Netgear 8 Port Gigabit
Kindly check the Gateway used in the computer where internet is working.....
to find gateway follow this
start menu >>> RUN>> CMD>>>> Ipconfig
then configure this gateway in all other systems and ask for DNS from you isp as well..to provide DNS manulay.
If still dont work ...
tell me the all information you get by useing ipconfig command in the PC where internet is working.
like IP address
Gateway
DNS
i will make you a map to follow.
best regards,
Dec 02, 2008 | NetGear ProSafe GS108 8-Port Gigabit...
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
3 netopia 2247 routers daisychained
How far are you running the CAT5 cables from house to house?   CAT5e only has a solid range of about 150ft, and anything near 100ft is pushing it.  You may also need to use CROSSOVER cables when plugging routers into other routers.
Also, who has the actual internet connection?  I'm assuming House 2 does.  One big problem is a router is your Gateway address.  And, if house 2 is the only one with a valid Internet connection (via DSL or Cable, etc), then the router in house 2 is the only "true gateway".  And, all 3 houses need to be in the same physical network (i.e. 192.168.1.0 range or whatever), and all computers should have the same Gateway address...which would be the IP address of the router in House 2.
What you really need in this situation is 1 router and 2 switches.  Put the router in House 2 and put switches in House 1 and 3.  That would be the best way to handle this problem.  It would also end your connectivity problems.
Cheers!
Jul 11, 2008 | Netopia 2247NWG-VGx Wireless Router...
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Linksys 8-Port (SD208) 8x10/100 Mbps Networking Switch Logo
158 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
