Question about SuperMicro Super Micro Desktop Motherb Motherboard
SUPER P4DC6 motherboard.
CAN A SUPER P4DC6 motherboard support multiple cpu's?
    Problem Solver:
  • 14 Answers
The P4DC6 supports upto two Intel Xeon processors this link will provide much more detailed information on your board, it also includes all updated software, drivers, bios files and manuals
Posted on Nov 01, 2007
There are three common failures with these systems.
CPU failure due to dust build up in the CPU cooler.
Power supply failure.
Hard drive failure.
There will be no "beep code" for any of these.
Jan 04, 2014 | SuperMicro SUPER 370 SSE (370SSE-TAIWAN)...
SUPER S4SCA Over Heat beep code
Dust build up in CPU fan. Blow out with canned air.
There may be a heat level setting in BIOS? Or, even software that came with motherboard.
Saw these on specs web site • SuperDoctor III (has fan monitoring) • Watch Dog
Oct 26, 2012 | SuperMicro SUPER P4SCA (MBD-P4SCA-O)...
I want to build a super computer with ASUS motherboard with 18 memory slots and maxumum 144 GB of DDR3 memory. With this motherboard, what are other special items to make this super machine work? --2 TB...
If you can get your hands on this I say get it but its about $1000.00
and as for power go for 1000 watts see here
hope this helps
Feb 01, 2011 | ASUS Intel Tylesurg 36D LGA1366 E-atx...
Will not start 2 long beeps
First off, if you recently upgraded the memory or CPU, put the old components back and see if the upgrade was the cause of the problem.
Next, make sure your power supply is connected correctly. Many motherboard need an additional power connector for the CPU. This will be specified in your MB manual.
Finally, make sure memory and CPU are properly seated in their sockets. Sometimes bumping into the computer or moving it can loosen them.
If you have multiple memory modules try testing using one at a time in different slots. This will tell you if you have a bad module or slot on the motherboard.
If this does not identify the cause inspect your CPU. Be VERY careful removing it. You may need to heat it up with a hair dryer to soften the thermal paste. Carefully inspect the pins/contacts on the CPU and socket to make sure none are bent, missing or dirty. Even if you don't see a problem the CPU could still be damaged. The only way to be sure it to try it in another computer or try an identical CPU in your computer. Once again, be VERY careful or take it to a professional.
Aside from that you may have a failure on your motherboard which is way too complex to cover here. You may be able to find capacitors that have the top split open or burn marks on the MB. The best bet is to have it tested by the manufacturer.
Please vote for my solution if it helps.
Dec 09, 2010 | Soyo KT600 Dragon Plus Motherboard
How can a mother board be repair?
Since motherboards have multiple "layers" of circuitry, it usually costs DOUBLE to TRY to REPAIR, when compared to the cost of buying a NEW motherboard that will be compatible with your current RAM and your current CPU.
Aug 16, 2010 | Computers & Internet
No power to GA-EP43-DS3L motherboard
When connecting your psu and its atx connector to the mainboard, have you connected the +4 connector ? If your psu does not have this extra +4 connector, you may need to buy one.
Also check you have connected the cpu power (12v 4 pin plug)
Nov 12, 2009 | Gigabyte GA-EP43-DS3LR Motherboard
Bios not starting
Gitu, remove tha fan, the cpu and the RAM. RE fix them in their respective places. Switch the machine on It shud work. Check the battery on the motherboard. May be it is dead. How old in your machine? Replace the button cell on the motherboard.
Aug 05, 2009 | Intel SuperMicro SUPER Motherboard - 810...
Cpu clock in my bios read only from 1200 to 1600 mhz.
Please read carefully the chapter 2 (page 33 and 47) of User's Manualfound at:
I suggest you select "Auto" on "CPU Speed" setting in the BIOS "Advanced" Menu or adjust 18x in "CPU Frecuency Multiple" if posible for reach optimal setting.
May 04, 2009 | ASUS P4S8X-X Motherboard
2.2 ohm 2 watt resistor
connect two 1.1ohm,1watt resistors in series.
Jan 15, 2009 | SuperMicro P4DC6 with FERRET RESISTORS...
Computers & Internet Logo
208 people viewed this question
Top SuperMicro Computers & Internet Experts
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
