First unplug the VCR then you can carefully unscrew the screws that hold the body to the base of your machine and you can carefully remove your tape !?!
Hello there daniel and thanks you for choosing fixya well it sounds like your vcr player may have a head that is dirty or the eject mechanism is either faulty or needs to be cleaned or repaired what you will have to do is remove all the screws holding the case on then remove the case this will expose the internal parts and there will be a small lever towards the rear of it where the band is at if you push back on it then you will be able to lift up on the carriage that holds the tape thus letting it free then remove the tape and carefully inspect all parts to see if any thing is broken or just really dirty a vacume with the wand attachment works well for getting out all the dirt and stuff out of it aso clean the vcr head this is the part that reads the tape with some rubbing alcohol then if you can get some canned air and blow every thing out then reassemble the vcr and see if it now works ok Post me a comment if it still does not work
if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it.. * 1 Turn off the COMBO. and unplug it. * 2 Remove the
4x screws off COMBO on the sides and take off the DVD/VCR casing. * 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the
tape off from transport plug the device to power and turn it on..Don't
worry,you will see the eject mechanism starts moving back on forth,keep
the tape off it and let it eject..
* 5.When tape is out .If it
destroyed badly normally you should not use it however if the recording
in is valuable for you you can cut the chewed portion and splice it back together .(Pls see the video included...How to fix a broken VHS tape.) * 6 While it is open,place another Tape to see if mechanism works properly. and eject it... * 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working .. Hope this helps!.. Take care and please Remember to rate/vote and give us 4 Thumbs Up to continue for Helping out the Community :) http://www.youtube.com/watch?v=Q1PJWA2KGyg
It sounds like the tape is jammed in the vcr, remove the top cover of the machine this will expose the tape. If the tape is spewed in the mechanical section and around the video head, get a pair of scissors and start cutting the tape and carefully remove all tape particles, when all tape debris has been removed, plug in vcr turn on and eject. If the tape looks good, you may have a loading basket problem, bad idler ***. or broken drive belt. "Lets hope for the best"
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
there is an acrylic post inside that directs a light beam to several different places so when the light beam is broken then it tells other parts that the tape is loaded this could be broken off or if the tape broke off inside a piece could be wrapped around a capstan or drive post causing the machine to think it is at the end of the tape and to turn itself off.
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Excess tape slack and the drives are not able to correct due to age/ lack of service. See if you can get the cover off and verify that the machine is at least trying to shuttle the tape. If that's the case, the idlers need to be replaced...accordianman
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case.
If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside.
Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
You are almost on the right track. did you look where your finger was? what happened was you did not allow the blocking a photo sensor which mimicked the clear part of the tape and this caused the eject to take place. What was happening in your case was the arm would come fully out and the sensor would sense no tape so the VCR shut off in a trouble condition to prevent damage from ocurrin.
