Question about Home
How do you set pendulum clock - Home
3 Suggested Answers
  • 45270 Answers
SOURCE: adjusting time on a sterling noble regulator pendulum wall clock no buttons on back and cannot get cover off clock to get to hands
electric or battery operated ? unplug or take battery out for 1 hr
Posted on Nov 01, 2015
  • 35572 Answers
SOURCE: how do you set pendulum to match the clock time with chime ?
Pendulum movement may be independent and can't be synchronized with the chime.
Posted on Aug 17, 2016
How do i connect pendulum to grafather clock?
How to Attach the Pendulum to Grandfather Clock Hunker
How to remove and re hang longcase clock pendulum
If there is an identifiable maker of your clock, I would recommend you attempt to locate instructions pertinent to it. Perhaps there is additional help in a forum.
Grandfather Clock Forum for Clock Lovers
Sep 01, 2017 | Home
How do i reset the chimes for a Strausbourg Manor Quartz Movement wall clock? and what is the magnet for?
Try removing the batteries. Set clock to 5:45. Reinsert the batteries, and set to 6:00. it may take an hour for the clock to sync., but it should do the trick. The only thing I can think of for the magnet would be that it may have fallen out of the pendulum swinger where your pendulum hangs. Hope this helps. Good Luck.
Nov 07, 2014 | Home
Clock keeps correct time but pendulum does not move
Either the battery for the pendulum drive is dead, or the collective circuit that drives the pendulum mechanism is faulty. If the clock takes only one battery you can be assured it is the pendulum drive circuit. takesin this case, you can find aftermarket pendulum accessories on Amazon and eBay.
Feb 18, 2014 | Timeworks Harrison Gray Wall Clock 30"
How to set the clock clock gains time how to correct
You can speed up or slow down the clock by adjusting the length of the pendulum. This link will walk you through the process.
http://usedclockparts.com/9-clock-case-repairs/31-how-to-speed-up-or-slow-down-your-clock-using-it-s-pendulum
Jan 24, 2014 | Home
Pendulum wont swing
Clock may either need to be decked out from the wall at the top, or pushed all the way up against the wall. These clocks have inexpensive quartz movements that aren't of the highest quality. If the clock is more than a few years old, it may be that the electromagnet that impulses the pendulum back and forth has just expired. You might try Clockit.com, or maybe Timesavers.com to find a replacement movement. Hope this helps, Good Luck
Dec 04, 2013 | Sterling & Noble Scroll Pendulum Wall...
Pendulum does not move
Good details! Go to Timesavers.com
You can find a replacement pendulum unit there. Your pendulum mechanism probably has a bad coil. The coil is extremely difficult to repair.
Coaster model 900723 grandfather clock doesn't keep time
Everybody should know that the coaster clocks discussed here run on batteries. The timing mechanisms, the chimes as well as the pendulum all are powered by a battery. Changing the speed of the pendulum is impossible because there is no adjustment. Besides, it wouldn't matter anyway. The pendulum has now affect on the clock's ability to keep accurate time. It is purely aesthetic. This is a pretty cool looking clock and even has weights, but those are also purely aesthetic and do not move the way a classic grandfather clock weight would move. The moments with these clocks are not designed to be worked on. These clocks are relatively inexpensive (approximately $300) but do add a nice look to your home. Grandfather clocks snobs would say though; this is not a true timepiece. They're right... Sorry._1513.jpg
Nov 20, 2010 | Watches
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 | Watches
CUCKOO TIME ADJUSTMENT
http://antiqueclock.clockstop.com/CUCKOO.htm
1/8 inch movement of the pendulum bob is equal to about 3 min per 24 hours running.
-To increase the time of the clock, move pendulum up.
-To slow down the time move, pendulum down.
Regulation notes:
These novel clocks are at best only a "fair" time-keeper. You can expect 100 to 120 sec per 30-hour winding period. I recommend that if it is within a few minutes per winding, simply RE-set the time.
-The regulation obstacles are obvious:
1. Open pendulum, this allows even the slightest breeze from a fan, ceiling fan or even cross-winds inside your house to affect both time qualities and/or its running ability.
2. The Pendulum material is wooden, and sensitive to climatic condition, during times of high humidity the clock will slow down.
Hope this tip helps.
R/
David
Jan 26, 2009 | Novelty 96512 Cuckoo Phone
Home Logo
21 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
