Question about Bushnell Watches
Low hi line voltage
I want to buy a mains to USB adapter to charge my Bushnell Neo+ watch. Amazon do one with 5 volts 1 amp output. Is this suitable
How do I charge my watch?
To charge your Apple Watch: Plug the Apple Magnetic Charging Cable, Apple Watch Magnetic Charging Case, or Apple Watch Magnetic Charging Dock into its USB power adapter. Plug the adapter into a power outlet. You can also plug the charging cable into a USB port.13 Sep 2016
Check your battery and charge your Apple Watch - Apple Support
https://support.apple.com/en-gb/HT204608
Dec 09, 2016 | Watches
Why does it appear that distances shown on this watch vary considerably to other gps watches
check whether yours is miles ,yards or meters or lkms to get such large variations
May 21, 2015 | Bushnell Neo Xs Gps Watches
How do I set the right time for my location hear in Texas
click on this link:
www.bushnellgolf.com/downloads/neox-watch-fullusermanual-2013.pdf
Jan 16, 2015 | Bushnell Neo Golf GPS Watch
Bushnell parts
go online with Bushnell. Customer service should be able to help you.
Jun 06, 2014 | Bushnell Neo Xs Gps Watches
Battery charging
Hi Patrick,
A rechargeable battery will eventually fail to accept a charge - just like your car battery.
The number of recharges a battery will be able to accept is dependent on a number of things, such as: temperature, if it is run to almost nothing before recharging (or if it is recharged after only being discharged slightly), how much of a load is on the battery and how fast (high amperage) or slow (low amperage) the battery is recharged.
Generally, cooler temperatures are better for batteries, as is using the battery almost completely before recharging rather than topping off after minimal usage, small loads are better (you don't have a choice in your GPS watch tho) and a slow or "trickle" charge is better than a fast, high current charge (you may not have a choice on this either). A few hundred discharge / recharge cycles is not uncommon - significantly less if the battery isn't cycled properly or used in harsh conditions.
I hope this helps!
Jul 01, 2013 | Bushnell Neo Plus GPS Watch
I lost the Wrist Net power supply but I do have the charger base. What voltage is the power supply?
Wow, I haven't used my SPOT watch in years--but I found it!
The charging base for my Abacus AU4000 uses an adapter rated at 12 volts, .11 amps, center positive. I believe that all the charging cradles for the Abacus Wrist Net series watches were the same--the different model numbers referred to different case and band options.
Good luck, and don't hesitate to follow up if you have any additional questions.
May 26, 2011 | Fossil Abacus AU4002 wristwatch
Ademco 6128 keypad beeping at random times & says bat on the display screen now - is there a battery in there we need to change?
you need to change your main control battiery.
the main control panel takes a 12 volt 7 amphour or a 12 volt 4.5 amphour battery. the larget the amphour the longer the system will last when the power is out. available at fry's radio shack or on line. ps: if the key shows a zone number with the bat, that means you have a wireless sensor low battiery.
mj
Aug 29, 2009 | Honeywell 5804 Ademco Wireless Security...
Watches Logo
14 people viewed this question
Top Bushnell Watches Experts
Steve
john mabry
Are you a Bushnell Watch Expert? Answer questions, earn points and help others
