Question about Meccano Erector Spykee Mini Vox Robot
Instructions for the mini vox robot - Meccano Erector Spykee Mini Vox Robot
Vox mini led projector light blinking problem
I dont think it as solution. when power on, it has to show the VOX logo initially. Later we can set the i/p mode...
I had the problem with my new led vox projector. Larer I replaced it. now I got the same issue with the replaced product. Each time I used only 2 to 3 hrs the device. Waste of buying such brands.
Jul 28, 2013 | JAKKS Pacific Eyeclops Bionic Eye Tv...
Kobo vox power supply drawing
check with pick buzzer metter & find power switch connection to usb or" headphone socket.
May 29, 2012 | Kobo Vox K080-KBO-B Reader
How do you disable the VOX setting on a Talkabout MR350 2 way radios. I wan to use it with a headset, but do not want VOX on.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf You will find the instructions for VOX and iVOX on the bottom of page one, and at the beginning of page 2.
Be certain when plugging in your audio accessory that the radio is turned off. If the radio is left on inadvertently, you would have no control over the VOX settings, it would immediately be in a confused VOX mode.
Also, with most Motorola radios, if VOX begins to occur, turn off the radio, and then re-insert the audio device plug. And in some instances, pressing the PTT on the radio when you are having a VOX occurrence will put the radio back to push-to-talk status.
Best regards.
Feb 19, 2011 | Radio Communications
I need a operation manual
Do you have the Robosapien or Mini Robosapien? For the Robosapien, you can download the manual from WowWee.com (click Robosapien Manual.pdf). For the Mini Robosapien, it doesn't come with a manual -- there aren't very many instructions, and they all come printed on the box that it comes in.
Dec 19, 2010 | Wowwee Mini Robosapien Humanoid Robot
I lost my remote control. i need one. wath is the cost incluying shipping to puerto rico
The Mini Robosapien does not come with a remote control. The robot's hands can be manipulated by pushing and moving them.
Nov 17, 2010 | Wowwee Mini Robosapien Humanoid Robot
Hi,is there any chance i can buy the instructions for the robosapien v2? many thanks
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Oct 10, 2010 | Wowwee Mini Robosapien Humanoid Robot
I am having trouble programing VOX to work on motorola rdu 2020 2-way radios
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Instructions for setting the VOX sensitivity are on page 33.
According to the manual you program the VOX using the CPS (software). Three things which usually cause end-user problems are:
1) Failing to set the sensitivity to a number 1, 2, or 3.
2) Failing to have the radio shut off when plugging in the audio device (headset or earpiece)
3) Failing to use a VOX capable audio device. (Not all headsets and earpieces are VOX capable. Many with inline PTTs are not.)
If these items or instructions do not help, stop by your local Motorola dealer to discuss the problem.
Best regards.
Sep 22, 2010 | Motorola RDU2020 Two Way Radio
Motorola T5622 VOX Not Activating with Autocom Sys I have an Autocom (Kit 300) motorbike coms system. I bought the accessory cord that interfaces to the Motorola T5622, for VOX I have followed the Motorola...
Hi Folks, two seperate checks to do - to check vox on autocom and transmit on motorola. With the T5622 unconnected to anything, does the push transmit button work - e.g. does it make the beep noise at the end of transmission?
Does your autocom work with any other sound sources - i.e. mp3 player so you can hear music. Does this mute when you speak ? (it should if vox is working). Note that in this setup vox is provided by autocom - NOT BY THE T5622. The instructions you mention are for the motorola vox kit.
Wire the two together and you should get the motorola beeping through your autocom at the end of transmit - that's what my kit 200 does with my T5622.
Mar 13, 2008 | Motorola Talkabout T6310 (14 Channels)...
Meccano Erector Spykee Mini Vox Robot Logo
Top Meccano Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Meccano Toy Expert? Answer questions, earn points and help others
