Question about Staples SPL1506X (CrossCut) Shredder
Need a new motor - Staples SPL1506X (CrossCut) Shredder
Motor stops Dead
The motor is fine, you need and new walking belt and possibly a deck.
Oct 23, 2017 | Nordic Track Treadmill Motor 215392
Need to wire motor for oreck xl upright
Your new motor should be very similar to the old motor. Compare the two motors to see if you can determine where each wire on the old motor should go on the new motor. If you are not sure it may save you money to have it wired by a qualified repair person. If you hook it up wrong it may damage the new motor and/or other electric components of your vacuum.
Mar 03, 2014 | Vacuums
Air is cold. Compressor outside works. The condensor will run for a little while, then shut off while compressor is still running.
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. purchase a new capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor.bobicehouse_96.jpg
Sep 14, 2011 | Frigidaire FAS155K1 Air Conditioner
My engines dead and i need to put a new one in, i have a 98 chevy cavalier 2.4 twin cam engine currently in it (dead)
are you sure the engines gone? have you had at least 2 certified mechanics tell you that you need a new motor? in todays age, some people do lie for money.sad but true. try calling a local mobile mechanic and have them come out and diagnose it {the motor} bad. unless you're mechanically qualified to diagnose it yourself. then, try a pull a part junk yard for used motor or a local part yard for used motor. if you do prefer a new motor,you can order a new motor from dealer,auto-zone,advance auto parts. the new motor price,i do not know. the used pull a part motor,i do. the motor cost is with warranty,is $210.00 in tn. in ga. thats you pull the motor yourself. the motor from a part yard that pulls it for you can be anywhere from $500.00 to $950.00 depending on how many miles are on the engine that's being removed. 1st myself, i would need to know for sure that my motor is really bad.just like a dr. before doing surgery,you need 2nd opinion. sorry,just the way i am. if you're mechanically inclined and can make the correct diagnosis,you can find a good used motor. if not and you're trusting someone else for parts,labor,i suggest you consider the cost of replacement,the cost of the labor,versus the cost of the entire vehicle replacement into another car. that's only being honest. good luck and thank you for choosing fixya.com!
May 06, 2011 | Chevrolet Cavalier Cars & Trucks
The motor blew up, need to replace it. new or
A new motor will cost you 1000s . A used one will do if you are short on money. Places that sell used motors usually have a limited warranty on the motors they sell. They do a check up on the motor and refurbish it. they give you time to take it back in case it fails or anything else.
Nov 27, 2009 | 2001 Ford Windstar
Whirlpool dishwasher noisy needs new motor
You may not need a new motor. If it is "buzzing" it may need a new small run capacitor - that can dry out and fail.
If the pump is noisy (but working) it may need clearing - or if worn - replace the pump.
Only replace the motor if the bearings are badly worn or armature damaged.
Sep 30, 2009 | Home
Need to replace motor on a Simplicity upright vacuum and need help with the wiring the new motor. New motor is different from old one.
You might not have the right motor. Take the old one with you because it should go right back in as easy it was to remove.
Aug 22, 2009 | Vacuums
Old capassitor has 3 prongs new capassitor has 2 prongs
The old motor relied on a leg off of the ol cap marked FAN. No need to bother with it anymore because the new motor probably has a different cap rating therefore it needs its own wittle capacitor. Cute ain't it? That new motor will probably have a common wire to connect to that Old cap at the C mark on it though. It will have 2 brown wires to connect to that new cap for it. (insulate that cute little cap to prevent any shocktastrophies) The black wire will of couse go to wher the old one did on the contactor. Read a little ditty I affectionatly wrote for further info entitled 'old motor had 3 wires new motor has 4 WTF"
Jun 06, 2009 | Heating & Cooling
I have a Kenmore series 80 that I bought it used two years ago, it now has a bad motor, it was manufactured in '96. I replaced the motor coupling a month ago. My question is, is it worth replacing the...
hello, i'ld say buying a new motor is far cheaper then buying a new unit unless the maching is in bad condition for a new motor your looking at anywere from 50.00-175.00$ depending on the model number of your machine. good luck on making your decision, and if you decide to buy the new motor and need help finding one let me know i can help you find the motor you need.
Mar 22, 2009 | Kenmore 24442
Staples SPL1506X (CrossCut) Shredder Logo
55 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
