Question about LW Scientific Zipocrit Portable Hematocrit Centrifuge
Microhematocrit tube leak - LW Scientific Zipocrit Portable Hematocrit Centrifuge
GE profile side by side refrigerator leaking water from the bottom on the back right side at refrigerator tubing pressure connection. Model# PS123NGMD 88
Try tightening the brass fitting first. If that doesn't fix it, look at the tubing for the source of the leak. If there is enough tubing left after you cut past the leak then you can reuse the brass fitting and the tubing insert on the tubing. If not, then you'll need to get some tubing and a brass splice connector from your home improvement store to fix the problem.
Jan 03, 2015 | GE Refrigerators
The fuel line tube is leaking gas. how do i fix that?
exhaust the gas and make sure there is no more gas in the vehicle. Check the leaking line tube, and get the exact point that is leaking. But make sure you get the leaking point before draining or exhausting the gas.
If the fuel line tube is rubber, get an Abro Gum or go to any car part dealer store, you will get a gum that can seal up the leaking area or part.
But if it is a metal, you will have to take it to a welder or panel beater so that they can help weld or seal up the leaking line tube.
Good luck.
Nov 24, 2010 | 1997 Ford Escort
1999 Chrysler Sebring Coupe 2.5 oil in spark plug tubes. Replacing valve cover gaskets and spark plug tube seals at top of tubes. Concerned about bottom of tube. Is that an area that might also be...
It is possible the tubes are leaking at the bottom but highly unlikely. There is next to 0 oil pressure in that area so the tubes would actually drain if leaking. I would start with the tube seals and gaskets as you have already planned and check it again later down the road like at the next oil change interval. You're on the right track for the repair, just be patient with the intake plenum and you'll do fine.
Jul 27, 2009 | Chrysler Sebring Cars & Trucks
Water leak in ice maker tube
Hi, Make sure the inlet tube has no restrictions. Sometimes ice will start to form inside the inlet tube and cause pressure so the hose leaks. If this does not help. you might need to change the change the inlet tube
Please let me know if I can assist you further.
Vic
Jun 20, 2009 | Refrigerators
What is the white part that holds water tubing on back of Amana refrigerator? It is leaking water around the tubing
hi,
tubing at the back refrigerator is the condenser, function of this is heat rejection that absorb from your evaporator inside your refrigerator,the white part of holding tube condenser is tube holder mounted by screw to hold condnser tubing has no relate inr efrigetration cycle.the screw use on tube holder was directly pin at the back side of eveporator where cooling effect emerge some ice melted or defrosted form water pass through on screw tube holder,you can fix loosen screw have some sealant pathced to hole where srcew located after a minute of drying time screw it again so that water leak may not come out to that tube holder through your condenser,
well,if that leak does not harm or not make any trouble passing through your condenser its still good condenser need to be cooled so that refrigerant inside tube can flow on liguid state effeciently.on large refrigeration such as ice plant
condenser was designed to have a water shower on tube called evaporative system.it make coole the condenser tube.
this ideas can give you clear explanation why water leaking on tube condenser.have anice day rate me,thanks a lot
May 04, 2009 | Refrigerators
Water Pump leakes from steel tube.
when installing new o-ring on tube, lubricate o-ring and stick it in water pump. Then pull pressure back on tube and then tighten hold down clamp. problem solved
Apr 16, 2009 | Dodge Caravan Cars & Trucks
2000 yamaha ttr90 fuel leaking out overflow tube
your float is stuck take carburator off and clean wiggle float and it shouldnt leak gas anymore
Apr 04, 2009 | 2002 Yamaha TT-R 125
Fuel Leak
Recommend replacing the fuel lines. They only last a couple of years before they get brittle. The fuel line if very inexpensive and can be found just about anywhere.
Jan 27, 2009 | Garden
Evap leak in fuel
Remove the gas cap and re-install it making sure that you hear it click several times. What your evap leak could be is the gas cap allowing gas fumes to escape. All it takes is a .040 leak to turn on the engine light. If it persists you'll have to have the emission system smoke tested. What happens is the system is literally filled with smoke and the leak will be found by where the smoke comes from.
Nov 23, 2008 | 1998 Buick Century
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
LW Scientific Zipocrit Portable Hematocrit Centrifuge Logo
Top LW Scientific Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a LW Scientific Science and Laboratory Expert? Answer questions, earn points and help others
