Question about Acer Aspire 4520-5582 Notebook
No sound coming from the realtek digital output
My comuter says that its working properly but i dont hear any sound at all and i use windows Vista
    Sergeant:
  • 361 Answers
U can check sound stall or not two way as 1/ right mouse click-clik hardwere click device manager then look sound option ,if sound is not stal u con see there yello sign in speaker. if not stall sound keeping ur bord cd ,u can stall sound. 2/ go run type control and click sound and audio option then look on audio device property . if setting is incorrect correct it ----- thanks
Posted on Jun 14, 2009
I need the audio output device to be installed on my computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if you dont have a motherboard disc you will have to download the drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Realtek AC'97 audio driver package. The package includes: driver setup program, drivers for Vista/Windows 7 32-bit and 64-bit editions.
hope this helps
Update your embedded sound from Realtek to the latest AC'97 codec.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
Download the driver software by
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
http://www.boxdrivers.com
using this link you will be able select your drivers
hope this helps
Jun 23, 2011 | Computers & Internet
HI I HAVE A DELL VOSTRO A860 AND I JUST INSTALLED WINDOWS 7 EVERYTHING IS WORKING FINE EXCEPT THE SOUND IVE DOWNLOADED VISTA DRIVERS REALTEK AND CONEXTEANT DRIVERS BUT I CANT SEEM TO GET THE SOUND TO WORK...
If you hear the sound on the headphones then the drivers installed correctly and the defect is either hardware - the jack for the headphones is stuck so the internal speakers are no longer activated when you unplug the headphones = the jack will have to be replaced by a shop - or software - you will have to go into the Realtek HD Control Panel and configure the audio outputs correctly = enable or unmute the internal speakers.
The Panel icon can be found in the notification area or in Start > Control Panel.
May 10, 2011 | Dell Vostro A860 Notebook
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
Bose Companion 3 and Realtek HD Audio Card - No sound
Hi: I'm sure you checked the volume control of the Bose controller. Check where you plugged it in to the back of your computer. Mine has a veriable outpup and a fixed output. I hope this helps, Jeff
May 31, 2009 | Dell Computers & Internet
No sound Acer 6930 XP
Your machine does use the Realtek audio codecs. Try to download the version available on their website. You have two choices - a standard AC97 or the AC97 HD (you may want to try this one first) one of them should be compatible with your equipment.
NOTE: The drivers available from Realtek have a different version number with them but they are basically the generic drivers for AC97 devices.
Apr 04, 2009 | Acer Computers & Internet
NO AUDIO OUTPUT IS INSTALLED
Sounds like you are running Vista. If so, do you know if you are useing the RealTek Audio?
I found many references to this issue but I am not sure which may apply to your problem. Here is a set of steps to follow from another site: (Assumes Vista and Realtek)
  • Open Vista’s Control Panel (Window | Control Panel)
  • Open the Realtek Audio Manager (not “Sound”)
  • In the navigation bar in the far right, there is a little yellow folder icon. It is just below “Device advanced settings” and above “ANALOG”. Click the folder icon.
  • Click “Disable front panel jack detection” so that a yellow check mark shows up. Hit “OK”, and close the Realtek HD Audio Manager. That should re-enable the sound.
Mar 13, 2009 | Microsoft Windows Vista Ultimate Edition
i think your spund drivers are not updated as per your requirement and they are not working properly....
secondally it might b a problem in your volume controler or audio pin
Feb 22, 2009 | Creative Labs Computers & Internet
My audio doesnt work when i upgraded
Go into Control Panel --> System --> Device Manager. Look for a Sound device or unknown multimedia device. Try updating the device to Realtek audio. Vista should have it's own Realtek audio drivers. If you can't find it, go here...
http://www.everex.com/support/nm3500w/nm3500w_downloads/nm3500w_downloads.htm
for driver downloads. Honestly, I'm not sure if the Realtek driver listed there is the proper one, but it's the only one listed. Post back with how it goes.
Jan 04, 2009 | Everex NM3500 Laptop
No sound
Maybe you have the mute active. Double click the speaker in the bottom right corner of the screen and make sure the mute check box in unchecked.
Dec 26, 2008 | Microsoft Windows Vista Ultimate Edition
Acer Aspire 4520-5582 Notebook Logo
425 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
