Question about Tissot PRS 200 Wrist Watch
Tissot Chronometer is running all the time - Tissot PRS 200 Wrist Watch
How do i set the time tissot t touch expert
Hi. As it would take a lot of time to write and draw all necessary figures right here, I would like to give you direct page address for all TISSOT TOUCH EXPERT settings. If the print is too small - use ZOOM tool to magnify it. Hope it will help. Follow this link: http://support.tissot.ch/usersmanual/141-en.pdf
Jan 13, 2011 | Tissot T-Touch T33159851 Wrist Watch
I just bought the armani ar0142 but the second hand doesn't work. Is this normal?
Take closer look and you will notice the small seconds hand which should be working. The dig seconds hand actually is chronometer hand and will work only when the chronometer function is engaged. Push the top button once=chronometer will start. Push the top button once more=chronometer will stop. Push the bottom button once=chronometer will return to zero. Rate me, please.
May 18, 2010 | Giorgio Armani Emporio Armani Black/Steel...
How do i set the time on a tissot touch watch please
Download the manual from Tissot at: http://support.tissot.ch/?mod_flashPDF/id_138
Apr 30, 2010 | Tissot T-Touch T33759851
Touch only works on some functions now . centre touch does not work at all and thermo does not work, cant get the date of course
If you have had the watch some time then the battery might be running down.
Go to a watch shop and have the battery replaced. If this does not solve the problem, then you may have to take it to a Tissot dealer or send it to a repair depot.
If you need to look for a dealer, one can be found by going to the Tissot web site "www.tissot.ch", from the menu at the bottom of the page select "stores" and fill in your details.
Jan 22, 2010 | Tissot T-Touch T33159851 Wrist Watch
Festina chronometer. The hand that shows .01 secs does not return to 12 o'clock position. I would like to reset it if it is possible to do it using the buttons.
In chronograph mode but not running use the top left button 1 press at a time to advance the hand to the 12 o'clock position. Then return to normal moe - job done.
Jan 17, 2010 | Watches
Chronometer won't start
Not sure this is worded right. A chronometer is watch that has been certified by a Swiss organization to keep time within a set +/- seconds per day in several positions and temperatures.
A chronograph on the other hand is a watch that has push buttons on the side for starting/stopping/resetting a set of hands to mark time elapsed.
If this is truly about a chronometer not starting it is either a broken part or needs cleaning.
If it is about the chronometer not starting most likely if it is a mechanical watch the pusher is stuck or broken or a lever is out of place or bent. If the whole watch does not run then it could be a broken mainspring.
If it is a quartz chronometer it could be a bad battery or if the battery has been changed it is most likely the person that changed the battery has damaged one of the coils and or circuit.
A qualified watchmaker can help with any of these problems.
Hope this helps,
Ken Kotoski
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 28, 2009 | Breitling Watches
Tissot prs516 & it runs fast 1 minute every day
There is a solution, but you have to wait a bit. I'll contact Tissot tmrw and then will give you advise. It's 3.15 in the morning over here, so, need a little rest.
Aug 14, 2009 | Tissot Prs516 T91141731 Watch
I need to know if I need to purchase a watch winder for my TAGs
Use a winder if you must but I recommend just winding and setting when you want to wear them as most winders I have seen are very cheap and unreliable. Expect up to 50 hours from most watches usually not less than 30, this is if the have recent< 5 years, overhaul.
Jun 11, 2009 | Tag Heuer Link Automatic Chronometer...
How do I use my watch???
I also own a PRS200. The two buttons on the right and top two subdials are for the chronometer function.
The top right button starts and stops the chronometer function: First press starts the chrono. Second press freezes/stops it, so you can record your time. Third press resets the chrono.
The bottom button is for the lap function: on the first press, it freezes the chrono in order for you to be able to record your "lap time", but keeps the chrono running in the background (you don't see this, it's the movement that does this mechanically). When you press it a second time, it jumps back to the running chrono time. You can then press it again to get another lap time, and so on...
In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Feb 23, 2008 | Tissot PRS 200 Wrist Watch
Tissot prs200
I also own a PRS200. The sub dial at the top left shows the minute count when you use the chronometer function. In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Dec 23, 2007 | Tissot PRS 200 Wrist Watch
Tissot PRS 200 Wrist Watch Logo
27 people viewed this question
Top Tissot Watches Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Tissot Watch Expert? Answer questions, earn points and help others
