Question about Business Source 20877 Professional Document Laminator BSN20877
Laminator model #20876/20877 is making loud thumping noise and won't pull sheet through
Thumping noise and won't pull sheet through
How do i get my Fellowes Venus 125 Laminator 5215901 to stop bleeping and heat up ?
Unfortunately, this message was posted in the section for paper shredders. If you still need an answer you will need to repost it.
Jul 16, 2014 | Fellowes Venus 125 Laminator 5215901
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
The dryer works but makes a loud thumping noise model#GLEQ642AS2
All dryers have some type of roller system that supports the drum as it turns. It sounds like one of the rollers or roller bearings has worn and is making that thumping noise. If you have some basic skills and good general mechanical sense you could fix it yourself. Make sure the dryer is unplugged before you attempt anything.
Feb 25, 2011 | Frigidaire Dryers
Loud thumping noise
a roller under the drum has a flat spot
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Have GH6177XPS. Everything works normally. Have had about six weeks. Started making loud noise when cooking (similar noise as when computer fan might be going out or running a long time. repairman came...
It would be unusual for even a Chinese fan to have failed bushings in that short period.
If this unit has a conventional power supply for the magnetron, the noise might be caused by the magnetic field of a large power transformer. These can have a strong stray field and can cause other sheet metal near them to vibrate.
It isn't dangerous, assuming you don't poke a finger inside, to remove the rear panel and inspect the innards while it is operating. Using something that isn't metal such as a plastic or bakelite spoon (even dampness in a wood utensil can conduct a painful shock), you might try damping the vibration with it. If you can locate the source, you may be able to kill the resonance by applying a fairly large bead of pure silicone (nothing else) to the surface making the noise.
It it seems to be coming from the transformer itself, I would pull the plug, let the unit sit ignored for a couple of hours (there can be charged capacitors inside) then use a finger to press silicone into the transformer's laminations. These were once soaked in epoxy in a vacuum container to **** all the air from between the laminations to prevent exactly this kind of 'rattle.' They probably don't take the time for that any more.
Apr 01, 2009 | Whirlpool GH6177XPS Microwave Oven
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Loud thumping noise in rear air
Hi, you should check if the blower plastic fan is rubbing against the fan housing ,they get lose with time and make those noises.good luck C1...
Nov 27, 2008 | 2003 Chevrolet TrailBlazer
Business Source 20877 Professional Document Laminator BSN20877 Logo
Top Business Source Office Equipment & Supplies Experts
k24674
Are you a Business Source Office Equipment and Supply Expert? Answer questions, earn points and help others
