My 2wire router keeps on restarting when I plug it into the wall. The first light (power Light) goes green after a few seconds, then the Broadband link goes green after a few seconds but then the, local network light blinks green one time and the whole process starts all over. I have no chance to go into the settings and reset the router. Also note that if I use the original adapter that came with the router, the router doesn't even turn on the lights. Instead it makes a whining noise, which you can barely hear. So I am using an old phone adapter that works great and actually turns the lights on. I made sure all the connections were good. I also called my ISP which is ATT and they told me that its out of warranty so I should get a new one. Any help would be appreciated, thanks.
Comments:
Jun 14, 2009
- I don't have an ammeter to test it, and it doesn't get hot at all even if I leave it with the plug on for 3 to 4 days. I'm talking about using the phone plug not the original plug. So what do you think is it bad?
I have a D-Link that had a similar problem. The power adapter that came with the unit wouldn't work, so I modified a PC power supply to power my router, so I could test the router. A component in the router had failed, (in fact when i powered up the router, this component got so hot that i couldn't touch it) and that's why the original adapter would not work.
Most likely a component has failed in your router. If you want to veryify this, use an ammeter to test the current draw of the router. If it exceeds the rated wattage then the router is bad
Comments:
Jun 14, 2009
- I wrote that a component inside the router gets hot, not the router itself. I explained to you how to test the router, if you don't have the ability to test it, then obviously you need to buy another one.
My 2wire modem keeps saying cannot find an ATM thing and no matter what I do it will not conect to...
(More)
My 2wire modem keeps saying cannot find an ATM thing and no matter what I do it will not conect to the internet
My AT&T 2wire router thing loses internet everytime I try to use it. It does not matter...
(More)
My AT&T 2wire router thing loses internet everytime I try to use it. It does not matter where I go in the house, the wireless is always black instead of green on the router. Even when its on it will say i have limited connection or none at all. There isnt anything wrong with my laptop so I figure I just have a crappy router. What should I do seeing as my father bought the damn thing with my money and swears up and down its my new laptop and not the router, even though i know that isnt true
