Question about KitchenAid Superba EQ Series 24" Built-In Dishwasher KUDE70FX
Installing dishwasher with hidden controls - KitchenAid Superba EQ Series 24" Built-In Dishwasher KUDE70FX
My Samsung dishwasher will not stop draining. I cannot stop it, except by turning the breaker off. When I turn the breaker back on, it continues. Help!!!
It is stuck on a particular cycle. If electronic unit, see if there is a reset switch on unit. If not check out with samsung for hidden code to do so. If reset is unsuccessful you may need a controller/control board.
Sears has all sorts of parts for appliances.
Sears Online In Store Shopping Appliances Clothing More
Sep 16, 2017 | Samsung Dishwashers
Why won't my kenmore ultra wash dishwasher drain?
It could be an obstruction in the drain hose (most common), or in the air-break (if you have one), or at the check valve, or something may be blocking or stopping the drain pump impeller. Try this: Close the door and press Cancel. (Or if your dishwasher has the controls that are hidden under your counter ledge when you close the door, then press Cancel first and then close the door. Do you hear anything? Is the drain pump trying to run? If so, then start at your garbage disposal and work backwards. If you got a new garbage disposal installed, make sure that you (or the installer) remembered to knock out the hard-plastic plug at the end of the dishwasher connector port. Also make sure you don't have a clog right there. If that's okay, then check the drain hose (or air-break, if you have one) for clogs. If that's okay, then you will probably want to call a professional because the next steps involve removing and dismantling the drain pump.
Jul 05, 2014 | Kenmore 15899 Built-in Dishwasher
Dishwasher LG noisy operation
Check the machines water pump bearings, if rusted and damaged due to leaking water seal you will have to replace the pump as it is a sealed unit.
Feb 09, 2014 | LG 24" BuiIn Dishwasher w/Hidden Controls,...
I purchased a whirlpool dishwasher GU2475xtvy2 with interior controls on top of the door. Might seem like a silly question, however, do I have to install with the door & controls controls out from...
It is up to you as to where you fasten the dishwasher at...if you push it back too far then you will have to do the setting before you close it which is no problem... but if you want it out a bit then you can do that and you will have a hip knocker that you will always be cussing at...
heatman101
Apr 23, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Asko dishwasher d3232xlfi has control buttons on the top of the door. How do I install my granite counter top? Do I cut it out so my fingers can easily use the controls?
Normally the controls can be set with the door open and upon closing the door activate the washer with the options that were chosen. Normally, you wouldn't see a cutout made for the washer controls. These are intended to be hidden when closed. Good luck.
Mar 31, 2009 | Asko D3232XLFI Dishwasher
Need installation instructions for a Bosch dishwasher with hidden controls, possibly SHX36L 12UC 24-in under counter dishwasher. It comes to me used with no instructions and the usual install makes it...
go to thermador.com to view manuals. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Control panel cover falling apart
i looke dup your model and you seem to have the hidden control panel model. the manufacture is funny htat way they will only cover part if you have installedby auth servicer, i looked up the part for you part number 8531269 retails for about $70. its the enitre console assy including overlay. so although they cover it youd be better off buying it direct and installing your self for sure. simple enough repair, the screws (torx15) from the inner door panel come off and release the panel, everthing on the inside simply unsnaps and gets transferred to the new part. just remember to disconnect power first all live wires!
Nov 06, 2008 | Dishwashers
Hidden control panel not accessible on dishwasher
no thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
Feb 28, 2008 | Dishwashers
KitchenAid Superba EQ Series 24" Built-In Dishwasher KUDE70FX Logo
14 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
