Question about Emerson LC401EM2F 40" Inch LCD Full HD TV
Power supply clicks wont turn on - Emerson LC401EM2F 40" Inch LCD Full HD TV
My xbox power box is displaying the amber light and the xbox wont switch on is this related??
An orange light is illuminated on the power supply for one of two reasons. Either the console is turned off or the power supply is disconnected from the console. The orange light means that the power supply is in standby.
Even if the console is turned off, the power supply light may still be illuminated orange. This can occur if the power supply cord is not fully inserted into the power socket of the console.
Click Here For Toubleshooting
My YouTube
Click Here For Live Tech Support
Apr 18, 2013 | Microsoft Xbox 360 Console
Conia tv plasma clicking wont turn on
someone needs to look at the power supply as the clicking may be a physical relay on the power board.
Aug 26, 2012 | Samsung Televison & Video
Magnavox plazma 50 inch flat screen wont turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Televison & Video
I have a sharp-aquos flat screen tv model#LC-37GB5U and my problem is it turns itself off and then wont come back on.yesterday it worked perfectly,today it wont even turn on.when i push the power button...
Power supply board it dead.Replaced the power supply board should solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board. .
Jan 20, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Tv clicks but wont turn on
power supply board has probably failed, common problem. call1-800-samsung for nearest service center.
Nov 25, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Turns off automatically and clicks
It could be a Bomb?...But usualy is the power supply. The capacators are under-rated and go bad.
Rated at 10volt and not 16volt or better. Replacing them is the best and cost effictive thing to do. Replacing the power supply,will give you the same problem down the line. Fixing it properly will solve it
completely.
Nov 03, 2009 | Samsung PS42P2S 42 in. Plasma Television
Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Mar 20, 2009 | Televison & Video
Samsung 46in lcd wont turn on
the power supply has failed. On the power supply there are 4 caps which go bad because of the low value. if you want to give it a shot at repair replace them if not replac the power supply
Mar 17, 2009 | Televison & Video
Emerson LC401EM2F 40" Inch LCD Full HD TV Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
