Question about Panasonic 52LCX1516 52 in. Television
Power is on and no sound or picture
Power is on . no sound or picture. then after 1min or so it turns off
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Sep 14, 2012 | HP Computers & Internet
Carrier outside Unit will not power on. Every 45 sec's to a 1min it will make a humming sounds like its trying to power on but wont. The fan unit inside will come on but will not disburse cold air
You probably have a bad run capacitor in your outside unit. You will need to cal a service tech to test and replace it, until then turn your system off until it is repaired. Continuing to try to run it will over heat the compressor and fan motor and cause them damage.
Jun 16, 2011 | Carrier Heating & Cooling
Turn monitor on picture stays on for about 30 sec to 1min then goes off.
If it is just the screen going dark then your backlight controller is faulty and needs repair.
Mar 02, 2011 | Dell Computers & Internet
Brand new L7680. Just set it up with the software and the screen is showing a failure signal 'Alignment failed. Refer to device documentation for details. All that says is run the process again. I have, 5...
This not an issue w/ the software. please follow these steps...
Solution #1 Clean all the inks
  1. open the cartridge access door.
  2. take out all the inks that you have on the printer. (put them on the table upside down)
  3. get a wet clean cloth.
  4. on each cartridge you need wipe it out the electrical contacts on the ink cartridge it self.
  5. put the inks back in to the printer.
  6. close the cartridge access door
  7. turn off the printer
  8. unplug/disconnect the power cable
  9. wait for 1min.
  10. plug the power cable back in back in to the printer.
  11. turn on the printer.
  12. access the setup menu (press the wrench icon on the printer or setup button)
  13. Go to tools, then look for clean printhead
  14. align the printer.
Solution #2 Clean the printhead manually make sure that the printer is on.
  1. Open up the cartridge access door
  2. Take out all the inks that you have on the printer. (put them on the table upside down)
  3. Once you have take out the inks.
  4. Take out the printhead (printhead is the one that holding the inks)
  5. look for the printhead latch. (pull it up)
  6. Take out the printhead.
  7. Clean the electrical contacts of the printhead using a wet clean cloth again.
  8. Put the printhead and the inks back in to the printer.
  9. Close the cartridge access door.
  10. turn off the printer
  11. unplug/disconnect the power cable at the back of the printer.
  12. wait for 1min.
  13. plug the power cable back in to the printer
  14. turn on the printer.
  15. repeat cleaning and aligning the printer by going to tools under setup menu (wrench icon).
Solution #3 Reset the Printer
  1. While the printer is on unplug the power cable at the back of the printer
  2. On the printer press the # and number 3.
  3. keep on pressing for 1min.
  4. After 1min. plug the power cable back in to the printer.
  5. If the printer is not turning on press the on/off button.
  6. You should get a message "part NVM reset" , then follow the following task. (cleaning and aligning printer).
If you still having issues w/ it call HP printers support department 1-800-474-6836
Good luck! :)
Jan 31, 2011 | HP Officejet Pro L7680 All-In-One Printer
My tv will turn on there is no picture and it
Hi.
The only two parts that can cause scratching sound are the color wheel (if present) and the cooling fans.
The TV must be taken apart and tested by a technician.
To get in touch with a qualified technician ring the number listed on the user manual or check your Mitsubishi support website.
Regards.
Ginko.
May 11, 2010 | Mitsubishi WD-65733 65" HDTV
My acer monitor shutdown after 1min on
Look inside to see if it has any bad caps in the power supply, also look for 5v and 12v in the power supply, 90% of failed monitors are due to bad caps, see examples here: http://s807.photobucket.com/home/budm/allalbums
Jan 15, 2010 | Acer AL712 17" LCD Monitor
Panasonic 52LCX1516 52 in. Television Logo
13 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
