Question about HP DESIGNJET 4520 INKJETPR EN PO FR CAN SP Plotter Printer
Hp 4520 42 inch plotters grinding - HP DESIGNJET 4520 INKJETPR EN PO FR CAN SP Plotter Printer
Hpt 1100ps Grinding Noise
Hi Steven:
It sounds to me as if you have an issue with the power supply. Most power supplies these days have a fan built in them. When you have a grindy noise like that it more than likely is the fan going out or the blades of the fan is dirty enough to put it out of balance. Move your plotter out so you can see the back. Get down and listen carefully to determine where the grinding is coming from. Once you determine where the noise is coming from . Get a flashlight and is there are vents in that area look to see if you can see the fan blade spinning.
You may have to unplug the machine, remove the back of the printer to get to the area. If the fan blades are covered with dust. Try some canned air to blow away the dust. If that doesn't work, remove and replace the power supply. For future reference you should be doing maintenance on your printer monthly by dusting and vacuuming the open vents. You would be surprised how much damage paper dust can cause. You can look up the parts for your plotter here.
http://h20141.www2.hp.com/Hpparts/Default.aspx?mscssid=14053ECEC05440BCB6ED850FCB3C2FC0
Good luck.
Jan 18, 2013 | HP Designjet T1100ps Printer
My hp designjet 500 doesn't recognize the I/O Card
By I/O card I assume you are referring to your JetDirect or the optional HP/GL2 formatter board, your EIO devices?
If you have them installed and the plotter does not recognize them.
Shut down the plotter then remove the power cord from the plotter or the wall and wait 5 mins.
Remove ALL EIO devices (JetDirect / formatter).
Plug the plotter back in and restart the plotter.
Test functions of the plotter.
Shut down the plotter and then add back only the JetDirect.
Start the plotter and check the function, and check if the menu will allow you to setup the JetDirect.
If successful, shutdown again and reinstall the Formatter Card (if you use one).
Test functions and check the I/O setup in the menu.
The idea in a nutshell, remove the cards and add them back one at a time to see which one if any is bad and causing the I/O to shut off.
If this does not help, you may need to replace the plotters Electronics module
Aug 16, 2012 | HP DesignJet 500 InkJet Printer
Hp 430 plotter
does the belt look ok? sounds like you have some rubber stuck in the motor gear.
Oct 22, 2009 | Office Equipment & Supplies
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Printer cutting off 5 inches from finished size from InDesign
teresa_marti,
Try to rotate from lanscape to portrait, or if plotting form Acrobat check auto rotate and denter from the properties. Since it pltted before and no resizing was don it has to be the printer preferences.
randy320sgi
Jan 07, 2009 | Adobe InDesign
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
HP DESIGNJET 4520 INKJETPR EN PO FR CAN SP  Plotter Printer Logo
14 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
