Question about Royal Sovereign Electric Bill Counter RBC-1003BK
Display screen keeps sayin EA4 - Royal Sovereign Electric Bill Counter RBC-1003BK
I have an electric dryer with error code EA4. What does that mean?
An EA4 code can mean that the heating element is bad. (It's actually a time-out error; the unit did not begin to heat up in a timely fashion.) If you noticed the dryer getting hotter in those ten minutes, then the temperature sensor in the dryer may be faulty.
With the heating element, sometimes the element will have an obvious broken wire. The other diagnostic test is to use a volt meter and check for continuity in the wiring (resistance). Note: make sure the dryer is unplugged when you access the wiring.
I hope this helps.
Jul 29, 2012 | Frigidaire Electric Dryer
Why doesn't my android touch screen work?
it is clearly that your touch screen is damaged.... i recommend you to buy a new touch screen and replace it....
Jan 28, 2012 | Logitech Lands Phones
MONITOR WENT DOWN AFTER THE SCREEN WAS GOING DIFFFERENT KINDS OF ZIG ZAGS WITH THE COLORED BACKGROUND ICON PICTURE GOING ZIG ZAG WITH THE ZIG ZAG LINES THEN SCREEN WENT TO BLACK WITH A SYMBLE SAYIN...
Sounds like you have power saver turned on. Go into "display properties" under "control panel". Go to "screen saver" Check your "Power" settings. Un-check "Hibernate" or look and see power settings are and adjust accordingly. If they are all turned off, check your BIOS settings on your PC. It mights have a power saving feature in there.
Apr 26, 2010 | Computers & Internet
WHAT SHOULD I DO
Hello
you need to check if your tower is giving display to your screen or not from my concern your screen is fine the problem is in your tower try to replace the RAM this will help
Regards
Manish
Apr 07, 2010 | ViewSonic VX922 19" Monitor Flat Panel
My wireless is connected but notworking
make suer the wep security key is proper run again the internet connection wizard and put the proper configuration.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 22, 2010 | Acer TravelMate 4200 Notebook
How to unlock oven. my oven is sayin loc on the front of display an it keeps beeping.
try cutting the power to the oven for 30 min. and see if it will reset itself. if this doesn't work i need the make and model to see the breakdown of the parts so i can help you. tks.
Oct 13, 2009 | Ovens
It keeps sayin clean disc and restart
You should clean the discs and restart it. Or blow out your console with some canned air. If this doesn't help csll X-Box
Apr 29, 2009 | Video Game Consoles & Games
Veo connect
it is your computer screen that is saying that you need to set the colors lower resolution
Aug 17, 2008 | Veo Connect Webcam
Royal Sovereign Electric Bill Counter RBC-1003BK Logo
Top Royal Sovereign Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Royal Sovereign Office Equipment and Supply Expert? Answer questions, earn points and help others
