Question about RCA 27" Tv Sdtv Universal R.c. connections 27 Inch Television Brand:27v513t
The tv shuts off on its own and reads no signal
How do i fix the Lip sync on our new TV?
lip sync is the combination of the two signal carrier frequencies being out of sync
one signal carries sound and the other the picture and they normally come together correctly but that can be upset by a blip in the power supply, problems in the signal from the station or atmospheric disturbance
try changing channels a few times , try shutting the set down and then restarting it
read the operators manual for any clues in the trouble shooting section
Lastly talk with a repair shop for any advice on how to fix
Mar 14, 2016 | Televison & Video
My tv is turning itself of,is it the tv,or could it be my foxtel making it do this,,,
It is most likely the TV. The provider can shut down the service and you might get a message that says either: "are you still watching" of the TV says NO SIGNAL. If it is no signal then the television would shut off after a time.
Sep 26, 2014 | NEC Televison & Video
I hope u can help me w a samsung HLR4667 DLP. It shuts down, after a minute or two. The picture is perfect, when it is on, and I have taped down the blue access panel switch, which I read could be...
Hello Glen Harrison,
Welcome, and thank you for using FixYa!
To answer your question: This sounds like a weak capacitor on the power supply board.
You are right though, I would recommend a Black Friday special! By the time you put in a $90.00 part with labor, you might as well purchase a newer unit.
Have a great day!
Nov 25, 2011 | Samsung DLP HL-P5663W 56" TV
There are two green lights blinking at the bottom of the tv. where the power light is..i believe it's the opc lights. the tv shuts of it self and the two lil green light blink...we put the tv power...
The tv main logic board known as a tv Tuner signal board it is the causes and the problems.The tv main logic board,the tv Tuner signal board it is shorted and not taking in and sustance power from the tv power supply board anymore that why tv Power and OPC LED lights indication are flashing together.This main logic tv Tuner signal board that the board where that take in the tv incomming broadcasting signal wire plug into it.U must replaced the main logic tv Tuner signal bard to fixed this problems.If U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main logic tv Tuner signal board for the replacement.Tries tv unplug,replug it back about an hour later.Tv might work again for awhile though,but to fixed this problems for good the main logic tv Tuner signal board must have to be replace.
Aug 22, 2011 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
My Samsung LN-T4069F momentarily shuts off and restarts frequently. The shut down is very short. Is this a firmware issue?
No,this problems it is the tv Tuner signal board itself have issues.Tv intermittently shutdown and restart wright back and tv work fine as nothing wrong wright?Yes.This problems it is the tv Tuner signal board itself have ICS chips grounding issues problems.These ICS chips on the tv Tuner signal board are surfaces mounted soldering works and are not on sale indivitually ICS to the customers,even if they do,it impossible to do surfaces mounted ICS chips parts work without a 1200 degree celsius convaer belt style wave soldering machine any how.The tv still work fine wright,just used it.When it shutdown for good and don't restart it wright back again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 03, 2011 | Samsung LNT4069F TV
Polaroid tlx-04011c shuts off by itself but blue light still stays on..sometimes stays on for a while but eventually shuts off
The problems is the Tuner board.That the board,where the coalax signal cable plug into it to get the broscasting signal.Tries Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 15, 2010 | Polaroid TLA-04011C 40 in. LCD TV
TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
Nov 28, 2009 | Sony Televison & Video
Akb error signal produced and TV goes to shut-down state
Yes mate, you can fix it if you know basic know-how in electronics. pls confirm to get further help as projection TV has high voltage risk inside and I want your safty 1st.
Aug 14, 2008 | Sony KP-53HS10 TV
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
May 20, 2008 | Televison & Video
RCA 27" Tv Sdtv Universal R.c. connections 27 Inch Television Brand:27v513t Logo
12 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
