Question about Samsung DV330AE Dryer
DV330AEW filter light turns on - Samsung DV330AE Dryer
Do Samsung dryers (Model DV330AEW/XAA)have an independent capacitor or does the whole motor need to be replaced when bad?
Check to see if unit has start capacitor. Go to attached web site for diagram . If no start cap is involved then make sure that the motor bearings are as friction free as possible and it spins freely.
Some motors in lieu of a start cap have an internal centrifugal switch that diverts the power from a start winding to a run winding. If that internal switch is fubar unit will not start unless you nudge it as you have been doing. If that is causing the hassle see if that motor part is available separately to save you some dinero.
Search Over 2 1 Million Appliance Parts
Feb 12, 2016 | Samsung Dryers
Are all dryer power cords the same except for being either 3 or 4 prong?
They are universal. Just hook the new up the same way the old one was, assuming it was wired correctly.
Feb 02, 2016 | Samsung Dryers
My samsung dryer dv330aew/xaa wont heat up is there a reset switch?
you can check the element with a multi meter for continuity. may also want to check the hi limit thermostat and the cycling thermostat, do u have full voltage at the terminal? sometimes a tripped breaker will give you half voltage say 110 instead of 220 and what u get is enough power to run the dryer motor but not the heat as it takes a full 220 to run heat
Sep 08, 2014 | Samsung DV330AEW Dryer
Blk terminal and plug burnt off Heater relay main PCB
Even if it wasn't a poor connection made during the assembly of the wire harness, it could've loosened up over time as your dryer was used being that when the clothes spin the inertia causes shifting of different things inside the dryer. How long did the dryer run before this happened?
Also gas dryers always have a fuse in them, I'd check that before you put it all back together too because chances are that if you have a burnt wire the fuse probably went too. The fuse is usually white, about an inch long and has to male end terminals on it.
Mar 18, 2013 | Samsung DV330AEW Dryer
How to change water filter?
Hi
Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill.
Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Where is the filter located in the refrigerator?
1. Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
2. Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill
3. Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
4. Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
5. Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Jan 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Kaz Honeywell Tower Air filter rest light
When the filter monitor light remains on, it is time to check/clean the IFD™ filters and reset the filter
monitor, if needed. With the unit powered on, insert the tip of a ball-point pen or paperclip next to the LED
filter check light and hold for approximately 5 seconds until the light turns off (Fig. 3). Depending upon
your individual usage (environment and hours used), you may need to check and clean the filters more or
less frequently. If the IFD™ filters are cleaned before the filter monitor light turns on, the filter monitor
should be reset at the same time.
May 18, 2008 | Kaz Honeywell Tower Air Purifier with IFD...
Samsung DV330AE Dryer Logo
47 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
