Question about Denon AVR-600 Receiver
Bad on/off standby switch\ - Denon AVR-600 Receiver
Lc195emx stuck in standby mode
Hi D
Sounds like the Switch Mode Power Supply is failing to Power Up.
Often Caused by Bad Electrolytic Capacitors inside the Power Supply Circuitry.
Probably a replaceable PCB Module.
Take it in to your dealer or Electronics technician.
Cheers
Mar 03, 2015 | Televison & Video
Hyundai 32
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 07, 2012 | Televison & Video
Tv turn off after switching on from standby mode
THE set has a standby power supply that runs 7/24 if set is plugged in--if that does not have bad caps etc it switches the main supply on and voltages etc come on and stay on CAN BE CHECKED WITH A METER OR if something is pulling voltages down it has to be searched for.
Mar 27, 2012 | LG Televison & Video
Tv turns to standby then when i switch it on nothing happens then 10 second or so later the standby just flashes
unplug tv for 3-4 hrs then try again. if that doesnt help you may have a bad powersupply.
Mar 21, 2011 | Televison & Video
No power
Do you get any indicator lights at all? If you do, the at least the 5v standby circuit is still working. Check the power supply fuse first, then look for 5v standby voltage, if you do have the 5V, then the problem can be in the controller board not sending the ON command to the main power supply when the power switch is activated, OR the main power supply is bad. Look for bad capacitors or bad/burnt parts.
http://en.wikipedia.org/wiki/Capacitor_plague.
Nov 06, 2009 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Standby lamp flashes
if the lamp light is flashing,remove the lamp and check it there is 98% of possibility that is bad.
May 19, 2009 | Initial HDTV-320 32 in. LCD TV
JVC TV AV-28R47SK - very slow to switch on and sticks in standby
your lamp is going bad you need to buy a new one
Mar 29, 2009 | Televison & Video
I have a sony trinitron Model kv27v65 that will not turn on. The standby/timer light blinks four times. It was working fine earlier today and we don't know what caused the problem.
Internally the 4 blinks means that the vertical deflection circuitry has Stopped.
This requires repair or replacement depending on your preference.
Sorry for the bad news.
Dec 27, 2008 | Proxim HOT-STANDBY PROTECTION SWITCH
Flashing standby message.
Are any of the buttons not making a click feel when you press them like maybe one is stuck?? You didnt say if the same thing happen with the radio as did with the cd. If it is then a switch is stuck or bad or a problem with the switch matrix for the Microprocesor . Only way to trouble shoot this is I would use a scope and check all of the matrix {ie scann lines as well as input lines for distortion or noise and make sure when the buttons are pussed that they change and switch accordinly. If they dont then the processors bad. Good luck
Apr 23, 2006 | Sony DAV-SC8 System
54 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
