Question about Gefen Rmt-848Ir Ir Remote - RMT-848IR
System not responding to remote - Gefen Rmt-848Ir Ir Remote - RMT-848IR
No respond on my remote
Change battery in the remote with a new one.
May 08, 2014 | Bose LifeStyle 5 Series-III CD Shelf...
Vehicle will respond but not lock/unlock
reprogram the remotes by following the vehicles owner Manuel
if you can't get them reprogrammed then its dealer time.
Mar 11, 2014 | 5301 LE 2 Way Car Remote Starter System
Python same as Viper?
Hello Anthony,
This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
Feb 03, 2014 | Directed Electronics 479V Remote Gen 2...
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
I need to know how to program remote
To program a new remote to the system; open door, turn ignition on, press and release valet switch one time then, press and hold valet switch. System will respond with a chirp. Now press lock button on remote. System will respond with a long chirp.Turn ignition off. Test system. Repeat for additional remotes.
Sep 28, 2012 | Dei 7641v Responder Remote 160xvl 7641
I changed the battery in my remote now my car will not respond
Reprogram the remote: press and hold the f button for approximately 8 seconds. the remote will flash three times. press the remote start button on the remote. the remote is now ready to pair. enter vehicle, turn ignition on, press and release button and antenna, immediately press and hold same button, the vehicle should respond with a horn honk and/ or light flash on antenna. While holding button on antenna, pres lock button on remote...vehicle should respond with a confirmation horn honk and/or light flash. Release button on antenna, turn vehicle off. Test system.
Jul 12, 2012 | 5101 LE 1 Way Car Remote Starter System
How do i get the lock and unlock on the screen to work on a viper 479v remoet
The two-way remote responds when in range. Also, the system that it is programmed to must be a two-way unit. If this remote was purchased and programmed to an alarm/remote starter, the alarm/remote starter must be capable of two-way communication.
Jan 25, 2011 | Directed Electronics 479V Remote Gen 2...
My keyless remote for toyota highlander wont work, how can i reprogram it?
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Oct 05, 2010 | APS20B Prestige Keyless Remote Alarm
Panasonic HT520 remote not responding
Hi.Im Dani from Spain.I have the same pb.To solve this problem-a new one remote.My remote its
a panasonic universal remote control dvd system eur7722x30(i dint find it but i find this:panasonic universal remote control dvd system eur7722x40;i need to see if its compatible(hope so)
This is the link http://cgi.ebay.com/Panasonic-Universal-Remote-Control-DVD-Syste-EUR7722XD0_W0QQitemZ130350261905QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1e597b2691
Good luck
Jan 24, 2010 | Panasonic SC-HT520 System
2way remote for Python 872 not working
Make sure that the responder is set for your car. this responder can work for multiple cars...The owners manual tells you how to check.
Dec 29, 2008 | 872 Responder LE Security Remote Start
Gefen Rmt-848Ir Ir Remote - RMT-848IR Logo
14 people viewed this question
Top Gefen Televison & Video Experts
Electro Med Services...
Are you a Gefen Televison and Video Expert? Answer questions, earn points and help others
