Question about Quoizel 1 Light Norfolk Outdoor Wall Lanterns Mystic Black
Setting light on times for a norfolk outdoor lantern
How to turn on threshold solar table lantern
Were you able to figure out how to get it to work? I have two that I can't get on either. Thanks!
Mar 23, 2014 | Threshold outdoor lantern: Tabletop Light...
How do you light a Chinese lantern?
Modern Chinese lanterns made for home decorations are filling the current market. These are available in shops coming in different shapes and colors. The current designs contain strings or cords that are used to supply power and for attaching the indoor home lanterns available. These lanterns use minimal amount of power and are able to use a battery for a long period. Hanging these lanterns on the wall creates a good finished look. The Chinese lanterns are easy to light up using their battery power sources as well as they are permanent objects unlike outdoor lanterns used during festivities and are later released to the skies above.
Aug 24, 2012 | Light Boating
I have a coleman propane lantern model 5417 that will not light. Does seem to be getting the propane. Appreciate any help or ideas. Thanks, Joe
Clean the hole in the tip of the generator, or turn the wire handle 360 deg. 2 or three times, and try to light the lantern with the wire handle in the down position.
I hope I was some help? Cheers David dwfarrell@gruvy.com
Dec 06, 2010 | Coleman Sport & Outdoor - Others
I have an exterior copper lantern with broken glass panels. the lantern is completley soldered from the inside out.
Contact a glass company, but also look for a stained-glass maker.
Stained glass is set inside a soldered frame. That person will have the tools to fix it.
You will probably have to get a handy-man to remove the outdoor lamp so it can be taken to the glass shop.
Oct 30, 2010 | Cooper Lighting Lighted Switch
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Doesn't GE make lanterns? I seem to own one.
GE do make emergency lantern. the one you own is a rechargeable lantern made for outdoor or indoor activities.
Jun 02, 2010 | GE SteelBEAM FluorescentLED Hybrid Lantern...
How to light coleman lantern
Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
Aug 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Coleman lanterns as collectibles
Coleman Collectors Guide 1903-1954.
Tucker & Ebebdorf
ISBN 0-9651407-0-9
This is an excellent reference with lots of pictures etc., it does not give the prices, however.
You can check Ebay for completed prices if you need an idea of value.
I have not found a book yet with accurate values on Coleman lanterns.
Apr 21, 2009 | Coleman Sport & Outdoor - Others
Quoizel 1 Light Norfolk Outdoor Wall Lanterns Mystic Black Logo
315 people viewed this question
Top Quoizel Home Experts
Donni Steen
Tom Chichester
Are you a Quoizel Home Expert? Answer questions, earn points and help others
